12-28-2012, 05:11 PM | #1 |
Newbie Join Date: Sep 2011 Location: Youngstown
| HH 35t motor burnt up in 10 min
I dont kno if i did something wrong or what but i got my dingo done i got for christams to get back into the scaling game today and took it out for a snowy first run. In about ten minutes it went up in smoke and im clueless to what went wrong, ive raced for awhile but havent a clue on anything about brushed motors. Im running stock gears, mip driveshafts, brxl esc. also i need to figure out if i need a new motor or should i just rebuild it or will it be fine since i stopped once it made some smoke, it does still work but makes a grinding sound. Help a newb out. Thanks, Cody |
12-28-2012, 05:19 PM | #2 |
Rock Crawler Join Date: Jun 2009 Location: summertown
Any binding without the motor in it? Does it roll Freely? What pinion are you running? Battery? Esc? Sent from my SAMSUNG-SGH-I747 |
12-28-2012, 05:46 PM | #3 | |
| Re: HH 35t motor burnt up in 10 min Quote:
20t pinion, 2s lipo(trackpower 7600mAh, 70c), HH brxl waterproof | |
12-28-2012, 06:44 PM | #4 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
I'll add to his list: What size spur are you running? Make sure the drive pins are in alignment on each MIP driveshaft, will cause binding/hopping/vibrations. If it let smoke out and noises followed, wouldn't hurt to have it rebuilt/checked. Could've had a winding come loose or something??? There's a few vendors on here that offer that service, though I'd probably send it to Holmes since it's his brand. Send him a message.
12-28-2012, 06:57 PM | #5 |
Rock Crawler Join Date: Apr 2010 Location: Kelowna, B.C., Canada
It sounds like you got a rock or something caught in between the motor can and the armature. Take out the brushes, undo the two screws at the top of the motor so you can twist the timing ring off along with the brush hood. Then pull the armature out and clean out the can with a toothbrush, if the commutator looks black you may want to have it cut if possible. Once done put everything back together and try it out of the truck firs and if it all looks good, reinstall. If this doesn't fix it it could also be a blown winding like Devil Inc said. |
12-28-2012, 09:22 PM | #6 |
spurs stock so whatever it is lol guess ill have to tear the motor down and see whats going on in there. still disappointed this went bad so fast, not a great start into scaling that id hoped it wouldve been |
12-29-2012, 12:57 PM | #7 |
Opened up the motor and a good bit of black and coppery dust came out This is what it looked like. Any ideas or still the same diagnosis |
12-29-2012, 01:05 PM | #8 |
| Re: HH 35t motor burnt up in 10 min Stuff like this lol |
12-29-2012, 06:40 PM | #9 |
| Re: HH 35t motor burnt up in 10 min |
12-29-2012, 07:33 PM | #10 |
The dust looks to be from the brushes. Pull the brushes out and see what they look like.
12-29-2012, 08:07 PM | #11 |
Rock Stacker Join Date: Oct 2007 Location: MD, USA
That's copper dust. Brush springs way, way too tight? Wrong brushes? The comm looks ok - not perfect, but ok...
12-29-2012, 08:21 PM | #12 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
holmes motors are great products, but any thing thats man made can have a defect even after final testing. a guy from our comps in ohio had a brand new 35 turn ( i think its the same motor you got?) ran it that day it was toast in 20 minutes. he contacted homes hobbies email. they made it right. don't lose hope they are good motors. good luck.
12-30-2012, 10:02 AM | #13 |
Thanks for the help guys. Im gonna email holmes tomorrow and see what happens. I was just hoping it wasnt something i did since im new to brushed systems which now i kinda wish i wouldve went with a sensored brushless setup but oh well.
HH 35t motor burnt up in 10 min - Similar Threads | ||||
burnt up motor #2. What do i get? | bmf24 | Axial Wraith | 24 | 09-10-2011 04:24 PM |
Burnt up stock motor? | Racerx336 | Losi Mini-Rock Crawler | 5 | 02-23-2009 12:27 AM |
