12-29-2012, 02:22 PM | #1 |
Quarry Creeper Join Date: Mar 2012 Location: Roseburg
| What turn motor for 2s
Im still a brushed n00b. I think Ive spent too much times with my brushless go fast rigs. Now that ive 99% finished a scale body Im looking for a brushed motor for the SCX10. Since my current system in it sucks I dont drive it enough to know it very well. Havnt even broken a part on it yet and Ive had it almost a year. Ill be running 2s on the rig for a long while yet. No plans of going back to 3s. All the go fast rigs run a pair of 2s packs. Would I be wanting to run something in the 35-45T range or will I still have enough wheel speed in the 55T on 2s with the Axial tranny and diffs? Ill be mostly trailing with the local scalers and some crawling when I can. |
12-29-2012, 04:29 PM | #2 |
Rock Crawler Join Date: Jan 2012 Location: Mcallen, Tx
55t is mostly for rocks and your not gna have any fun on a trail with a 55t I ran one for so long and then I switched to a 45t and it was night and day, and now I went 35t and it's a blast! It has wheel speed like a mother and still plenty of torque even though my rigs about 9-1/2lbs as of now fully equipped, and all I will ever run is 2s, just like you I never really break anything on mine and ill never go 3s I'm geared 14/87 right now but I could always go up to 16/87 for some more wheel speed but I like where I'm at now, also the tire size is a factor, I'm running ttc claws so I have more of a rotating mass meaning I'm rolling a little father than someone on flatirons lol Sent from Outerspace Using My iFreeze Ray Gun |
12-29-2012, 06:07 PM | #3 |
| Re: What turn motor for 2s
I'd recommend a at least a 35 turn, or better yet 27 or even a bit lower if you are limiting yourself to 2s batteries. I run a 27 on 3s and its about right. Wouldn't be happy with anything slower. A 45 on 2s would be painfully slow IMO.
12-29-2012, 06:12 PM | #4 | |
| Re: What turn motor for 2s Quote:
Gear down, volt up! I'm experimenting with motors at the moment, but for general crawling stuff I like the 35t on 3s. For bombing around or trail runs, something with a bit more speed is in order. You could also go with a sensored brushless system... | |
12-29-2012, 06:18 PM | #5 |
Honestly Ive run Traxxas Titan 12T motors in both my wraiths and my honcho and its oodles of wheels speed and tons of torque, but I had to gear down because my honcho would reverse wheelie if I stomped on the reverse too hard lol I did have to beef up a bit for the extra torque, MIP's, no slop HD lockers, aluminum chubs, knucks, and universals, and robinson trans beef with a steel spur but now she's almost bombproof. Sent from Outerspace Using My iFreeze Ray Gun |
12-29-2012, 08:21 PM | #6 |
im probably around 6-6.5 pounds right now with the new F350 lid. Im also running little tiny 1.9 dirt grabbers. i can probably do to gear up a little then. i am hoping to just run the stock in the box dingo gears. i also have a 15T to use though thats on my 17T i used to have in there. that was much too fast for me. i have a outcry on the mail so i should be good for 4s! itll probably never see even 3s though. all my go fast rigs implode but they are running 2s or 4s on way too much motor. the e revo is running a 6 pole brushless that does backflips on 4s with punch at 3/10 yet is smooth enough to crawl...of it had locked diffs. ive tried, the comp guys though it was pretty funny. |
12-29-2012, 11:00 PM | #7 |
Rock Crawler Join Date: Mar 2011 Location: hampton
i run a brood 35t on 2s geared 14/87
12-29-2012, 11:19 PM | #8 |
Rock Stacker Join Date: Sep 2012 Location: canton, ga
i ran a 12t on 2s in a scx but i think for trailing with a bit of crawling a holmes 35t or their 27t motor would do the trick
12-29-2012, 11:38 PM | #9 | |
Sent from Outerspace Using My iFreeze Ray Gun | |
12-30-2012, 09:29 AM | #10 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
i run the 55t on 2s in my honcho and ax10 and it would be way too slow for trailing.. i'd go for a 35t |
12-31-2012, 02:47 PM | #11 |
Rock Crawler Join Date: Jul 2009 Location: Little Rock, Arkansas
Hand wound 35T would be my recommendation. I use a 2S on my rig and I personally ended up settling on a 45T motor with a smaller pinion mounted to it as my preferred setup. I do very hard technical crawling with my rig as well as trailing, so that's why I like this setup. But a little extra speed couldn't hurt if yours will just be a trail truck, so that's why I vote for a 35T.
12-31-2012, 03:47 PM | #12 | |
But now that i run strictly group trails the 35t is my next step down for wheel speed and just to have that power on tap Because what's more fun than a scaler slinging dirt Sent from Outerspace Using My iFreeze Ray Gun | |
What turn motor for 2s - Similar Threads | ||||
Higher Turn Motor Vs Lower Turn Motor ? | ReignMan | Newbie General | 10 | 11-15-2009 10:40 PM |
higher turn motor or lower turn motor......... | bob1961 | Newbie General | 6 | 03-18-2008 09:16 PM |
