Southern SXC10 Build *Update* 8 Attachment(s) Parts List Electronics: Holmes Hobbies BR-XL Holmes Hobbies 540 Trail Master Pro Ace CS170 Ultra Torque Ti Gear Servo Stock Receiver Stock Radio Chassis and Suspension: Vanquish Products Front Shock Hoops Vanquish Products Rear Shock Hoops RC4WD King 110mm Shocks RC4WD Bulldog Winch R2J Stainless Steel Links with Traxxas Rod Ends RC4WD Mojave Body Font Axle: Vanquish Products Currie Rockjock Housing Vanquish Products Truss/Upper Link Mount Vanquish Products Lower Link Mounts Vanquish Products Servo Mount Vanquish Products 0 Degree High Steer Knuckles Vanquish Products C-Hubs Vanquish Products Titanium Tie Rod/Drag Link Vanquish Products Bearing Mounts Stock Universals Stock Locker Stock Gearing Rear Axle: Vanquish Products Currie Rockjock Housing Vanquish Products Truss/Upper Link Mount Vanquish Products Lower Link Mounts Vanquish Products Bearing Mounts Stock Axle Shafts Stock Locker Stock Gearing Drivetrain: Stock Transmission Housing Stock Transmission Gearing Stock Spur Robinson Racing 15 Tooth Pinion RC4WD 130-150mm Punisher Shaft II Wheel and Tires: Vanquish Products OMF 2.2 Scale Rockcrawler Buggy Beadlock Wheels x4 Vanquish Products SLW Hubs .850 x4 LockedUp RC Inspired 2.2 Rings x4 Proline 2.2 TSL Swampers X4 |
Re: New SCX10 with Currie Axles 2 Attachment(s) Here is a few at full flex, not to shabby. |
Looks good, great articulation! |
Re: New SCX10 with Currie Axles Holy applesauce those axles sexy |
Re: New SCX10 with Currie Axles They are VP is amazing. Going to pick up some solid brass tubing and start work on the truggy portion. Going to use a buddies Mojave cab for the mock up. I have never done any tube work before, any tips? |
Re: New SCX10 with Currie Axles looks awesome man. have you thought about doing the xr mod to make it wider instead of the wheel widener? i think that may be the route i go. |
Re: New SCX10 with Currie Axles You know I just saw that after I bought everything lol. It was also running Wratih c-hubs and knuckles, it looked sweet. It seems pretty sturdy so far, I took it out this morning and put a pack through it. Everything is still tight and holding strong. I have a Novak 13.5 brushless I may drop in it today. Lots of mixed reviews about it, but Ive never had an issue with mine. And its just laying there with no home. |
Re: New SCX10 with Currie Axles Quote:
looks sick either way. |
Re: New SCX10 with Currie Axles REALLY?!?! F*CK YOU NOVAK!!! I just got done saying never had an issue with the spare 13.5 system I had laying around. Got it installed ran it around the house for a sec, all seemed well. Took it outside for 5 minutes, ESC fried.........Just ordered a HH Trailmaster combo. |
Re: New SCX10 with Currie Axles 1 Attachment(s) Since I had to tear out all the electronics again I decided to clean up the wiring a bit, I am a freak when it come to wires. I got a few extra holes cut in the receive box, shortened all of the leads, re soldered everything. Got all of the wiring inside the receiver box, looks nice and clean. Now I have a wiring plan when my BRXL combo get here. |
Re: Southern SXC10 Build 2 Attachment(s) Got my Holmes Hobbies TorqueMaster ESC/Motor today after my Novak burned. Ripped everything out....again. Cut down and soldered all of the leads and managed to get all of the wiring inside the stock box. It has been raining all day here so I didn't get to take it outside so I had to settle for the living room. This thing is smoooooth. I am running it with a 3S 5000mah Lipo. This is my first HH setup, now I see how awesome they are. |
Re: Southern SXC10 Build Quote:
Re: Southern SXC10 Build awesome job on the clean wiring. |
Re: Southern SXC10 Build 1 Attachment(s) Thanks man, I am a total weirdo when it come to wiring, I get very OCD. Just ordered the meat and potatoes for my build, this will be my first hard body, and suggestions for painting? |
Re: Southern SXC10 Build How are you going to mount it . Please show pictures. Thanks |
Re: Southern SXC10 Build I dont know yet, I'm going to have to see how everything lines up. But i will snap some pics of how I mount it. "thumbsup" |
Re: Southern SXC10 Build Looks awesome so far |
Re: Southern SXC10 Build Yeah I was looking at that, I found some paint for outdoor furniture that is textured. They had it in black and I think if I sprayed the body black with that textured paint it would look like the body was rhino lined, which I am a fan of. Body should be here Friday, I cant wait. |
