12-31-2012, 05:52 AM | #1 |
Pebble Pounder Join Date: Aug 2011 Location: England
| Damn Slipper clutch
Ok I've researched the setting up of the slipper clutch and what I've found really hasn't helped me at all. I tried following the instructions in the manual but it just hasn't run the same since I replaced the spur gear and set it back up. When I push my RC along by hand it gets to a point in it's cycle and just locks up? This is the same as when I'm running it, when it gets to an obstacle with some resistance it just jams and rolls back. I've re greased the transmission and axles. Tightened the grub screws on the props and set it all up how I had it but nothing I do seems to work. I'm running the Standard AE-2 esc and I've reset it without any improvements. Someone Help!!!! |
12-31-2012, 05:59 AM | #2 |
Quarry Creeper Join Date: Sep 2012 Location: 01011
| Re: Damn Slipper clutch
Can you post pics pf the assembly? A slipper is just typically a matter of adjusting the spring tension. Im wondering if something got missed during reassembly?
12-31-2012, 06:04 AM | #3 |
Quarry Creeper Join Date: Apr 2012 Location: Marietta
Check your gear mesh between spur and pinion and make sure the spur gear isnt hitting the grub screw on the pinion gear. I tighten my slipper all the way down and then back it off. 1/4 turn. Other than that something must be binding somewhere. Maybe check the driveshafts and see if there is too steep of an angle at the universal joint.
12-31-2012, 06:12 AM | #4 | |
| Re: Damn Slipper clutch Quote:
The only pictures I will be able to get is from my iPhone but I'll get some up this afternoon Thanks | |
12-31-2012, 06:23 AM | #5 |
Ok so I now have power! No more stalling thankfully! I tightened it up more and swapped out 2 of the rear links so as too reduce the angle of the driveshaft. I will give it a proper test when the weather is better outside, but for now it's much better. It had been sat for a few months but luckily it runs fine now thanks! Although there is a bump every so often on it's cycle but I think that's just the tyre foams or weights in the front wheels |
12-31-2012, 08:16 AM | #6 |
Glad it's working better for ya! Any more questions just fire away.
Damn Slipper clutch - Similar Threads | ||||
slipper clutch? | bashin calfee | Axial Wraith | 15 | 03-20-2012 03:06 AM |
Slipper clutch ? | Gso125 | Losi Micro-Rock Crawler | 3 | 02-08-2011 07:29 AM |
I know... Slipper clutch again!! | RickM | Axial AX-10 Scorpion | 26 | 04-15-2010 10:00 PM |
AX slipper clutch | upnover1 | Axial AX-10 Scorpion | 5 | 04-16-2008 03:31 PM |
