12-31-2012, 11:05 PM | #1 |
Quarry Creeper Join Date: Aug 2006 Location: savage
| Wraith outdirves fit scx10?
Just curious if the wraith shaft outdrives fit scx10? I ****ed up drilling out my scx10 outdrives for my emaxx shafts and just wondering if wraith outdrives will fit? Thanks |
12-31-2012, 11:28 PM | #2 |
| Re: Wraith outdirves fit scx10?
The AX30435 outdrive shaft set is the one that fits the SCX10's transmission. The Wraith uses the AX30435 for the front output shaft and the longer AX30437 shaft for the rear output. |
12-31-2012, 11:43 PM | #3 |
Awesome thanks man, do you have the part numbers for the pinion shaft for the axles? I am guessing its those $30 gear sets so maybe I am just better off drilling those ones out.
01-01-2013, 06:22 AM | #4 |
The input shaft for the stock diff gears is AX30408. Drilling the shaft from a HD gear set will be interesting since they are hardened steel. |
01-01-2013, 05:54 PM | #5 |
| Re: Wraith outdirves fit scx10? TowerHobbies.com | Axial Input Shaft 5x29mm (2) Those guys? So I dont have to buy a gear set to get the wraith outdrives? |
01-01-2013, 07:24 PM | #6 | |
| Re: Wraith outdirves fit scx10? Quote:
You may need to replace the e-clip as it may get bent removing it. See below for part numbers. | |
01-01-2013, 08:33 PM | #7 |
Awesome thanks man
Wraith outdirves fit scx10? - Similar Threads | ||||
Wraith Spur gear Cover.. Won't fit my SCX10 | madkawi650 | Axial AX-10 Scorpion | 2 | 09-24-2011 05:12 AM |
ax 10 scx10 axles fit under the wraith? | Blaine | Axial Wraith | 2 | 09-07-2011 07:44 PM |
will this fit my scx10? | axialnut | Newbie General | 2 | 10-02-2010 11:30 AM |
Will SCX10 Honcho Kit Parts Fit on Older SCX10? | alexchen86 | 1.9 Scale Rigs | 4 | 12-23-2009 03:56 PM |
