01-04-2013, 10:42 PM | #1 |
Quarry Creeper Join Date: Nov 2012 Location: spanish fork
| front motor and t case conversion kit ??????
ok ive been searching, and kinda keep getting the same thing popping up, the GMC, or is it GCM machining out of canida makes a kit that mounts the motor and and trans in the front and provides a t case, my question is, is there some where else that has a kit, or those of you that have done this conversion could list up some parts that you have used to do this same thing. any help or pointing me in the right direction would be loved!! im not retarded ( on paper or reconized by the state of utah) but i just need to be educated on the right direction to go this swap..... i just dont want to order somthing off the internet and return it. thanks for reading louie |
01-05-2013, 07:09 AM | #2 |
Pebble Pounder Join Date: Oct 2005 Location: Noblesville , IN
| Re: front motor and t case conversion kit ??????
Here is a link to there site: GCM Racing WebStore-2012 - About Us or the vendor section: GCM Mount for SCX Front motor/trans and T-Case Hope this helps! Dave |
01-05-2013, 09:27 AM | #3 |
RCC Addict Join Date: Apr 2010 Location: Outdoors
They're sold out but you can figure out what parts you will need. top right in blue font here GCM Racing WebStore-2012 - SCX Mounts Combo Kit is a pretty good video explaining and showing the install. The kit also relocates the servo. |
01-06-2013, 01:07 AM | #4 |
Pebble Pounder Join Date: Sep 2012 Location: Queensland Australia
That's an awesome configuration - nice product! That's going straight to the top of my wishlist. |
01-07-2013, 08:42 PM | #5 |
Rock Crawler Join Date: Nov 2009 Location: Wasilla Alaska
Gcm is the way to go. I have a cross canyon chassis as well as the scx10 gcm conversion kit. Both are high quality and well thought out.
01-07-2013, 08:56 PM | #6 |
Rock Stacker Join Date: Aug 2012 Location: mchenry
Probly off topic but if you used that trans set up. Do you think you could use a dig trans and use the out put shaft that's not being used and make some sort of pto style winch? That would be pretty powerful and creative.
01-08-2013, 03:49 AM | #7 |
I need it because I only run in dust and sand - having the motor up front and high inside my inner fender wells would be the cleanest place it could be.
01-08-2013, 10:40 AM | #8 |
Quarry Creeper Join Date: Oct 2010 Location: Hendersonville
I too have been looking into the GCM stuff for SCX10s. I'm thinking about buying their transfer case, but I may make my own mount for the motor and the servo. It can't be THAT hard.... 2 weeks from now I will change my mind |
front motor and t case conversion kit ?????? - Similar Threads | ||||
GCM Mount for SCX Front motor/trans and T-Case | Generis | Axles, Trannys, T-case | 97 | 03-27-2016 06:59 AM |
Bruiser front axle conversion | the_ghetto_rig | General Scale Talk | 4 | 10-29-2009 03:08 PM |
Savage Motor Conversion Kit | sandblaster87 | Non Crawler RC's | 8 | 11-24-2008 09:16 PM |
front steering linkage behind front axle kit? | slip408 | Axial AX-10 Scorpion | 8 | 09-14-2008 01:16 AM |
