01-05-2013, 07:12 AM | #1 |
Rock Stacker Join Date: Nov 2012 Location: Shawnee
| binding at full steer
I have a completely stock dingo and at full steer (more so to the right than left) the motor doesnt want to turn the tires.. anyone know of a solution for this or what the problem might be? note: it works great and doesnt bind unless the tires are at full steer angle.. |
01-05-2013, 07:36 AM | #2 |
Quarry Creeper Join Date: Feb 2011 Location: The underground
| Re: binding at full steer
Do you have anything jammed in or wrapped around the dog bone? If it is just plain worn out it could cause a bind. Did you hit anything with it lately? Throw up a pic if you can.
01-05-2013, 07:53 AM | #3 | |
| Re: binding at full steer Quote:
honsetly i think i figured it out, I think my battery was getting low and when I turned the wheels all the way it was drawing more power from the servo and therefore not delivering the power to the motor, and no i dont have a BEC and Im not even sure the ESC does either its an ooolld LRP that is soon to be upgraded anyways does that even make sense? lol the kit is brand new btw and i have the pins lined up on the driveshafts so i know that couldnt be the problem EDIT: threw in a different battery and the problem is gone, so looks like i solved that mystery, weird though if you ask me Last edited by KC_crawler; 01-05-2013 at 08:38 AM. | |
01-05-2013, 10:15 AM | #4 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
It's called a brownout if the ESC stops sending juice when turning. BEC should fix this for you, it did for me when I started getting brown outs after going to larger tires.
binding at full steer - Similar Threads | ||||
axle bind at full steer | radster87 | Team Losi Comp Crawler | 2 | 09-27-2011 09:07 AM |
Can't get full steer | Rooney7783 | Electronics | 6 | 08-01-2008 10:21 AM |
Does your tires hit your links or shocks at full steer? | bi_eep | Axial AX-10 Scorpion | 6 | 02-20-2008 01:51 AM |
2 Wheel steer with full lockers? | BOSKIPPER | Newbie General | 1 | 01-19-2006 08:39 AM |
Front wheels Binding at Full turn | ripper7777777 | General Crawlers | 6 | 09-22-2005 01:31 PM |
