01-06-2013, 09:12 PM | #1 |
Pebble Pounder Join Date: Jan 2013 Location: Fortson
| Rcpilotjr's Dingo UPDATES ON NEW POSTS, CURRENT SETUP BELOW Current Setup Body-Stock Dingo Axles-Stock Ring/Pinion-Stock-38t/13t Pinion/Spur-13t/93t Drive Shafts-Stock WB8 Tires-RC4WD Rock Crusher X/T 1.9 Wheels-Axial 8 Hole BL Motor-Duratrax Photon Speed 20T Brushed Esc-LiPo Tazer 15T WP Servo-Hitec HS646WP Batteries-2S/7.4 LiPo 5000mAh Shocks-Stock With 30WT Oil with 1/2 Bumpstops Front Springs-Super Soft Main/Super Soft Secondary Rear Springs-Super Soft Main/Super Soft Secondary Front Suspension-4-Link w/ Stainless Tube Rear Suspension-4-Link w/ Stainless Tube ORIGINAL POST Hey all. First build into the area of a rock crawler/scale rig. I have no build pictures as I know you have all seen a TON of them. My current set up is an all stock Dingo kit. The power is from a brushed motor with no markings from an Exceed Driftsar, XL5 ESC, and BlackOps 2s 5000mah batteries (Ask your local Hobbytown USA about em', that is where I got mine). Steering is from a Turnigy 958 servo and all are guided by a DX3S. I had no issues with the kit except for the spacer that goes in the lowest gear of the transmission. It doesn't fit and it seems none do in anybody's kit. A great thing I'll give Axial is EXTRA PARTS! Had multiple ball links and eyelets left over as well as some axles. The only thing I'm going to do is soften the front end as I can't get full articulation before or just as it hits the bump stops. I do have two accessories on the way. A winch and the Reign RC light bucket/bezel kit. QUESTIONS- 1. Wraith interior- is there an install guide somewhere? I've just seen pictures after install but no "instructions" or tips. Last edited by rcpilotjr; 09-09-2013 at 02:15 PM. |
01-10-2013, 08:43 PM | #2 |
It is lit! With some pretty interesting connections. All LED's and such purchased from Radioshack. |
01-10-2013, 08:46 PM | #3 |
Newbie Join Date: Jul 2012 Location: BC
| Re: Rcpilotjr's Dingo
Intresting wiring
01-10-2013, 08:54 PM | #4 |
Quarry Creeper Join Date: May 2012 Location: Houston
Agreed! Thats some crazy ass wiring! What happens when it gets wet.....
01-10-2013, 09:09 PM | #5 |
Haha thanks. I haven't driven it in water WITH lights yet. We will see... I do know it is a solid connections as I can pick up the truck by the cage, shake it every direction and the lights don't flicker, fade, or cut out.
01-13-2013, 04:35 PM | #6 |
Well, spent four hours driving it around today at Flat Rock Park here in Columbus, Ga. I haven't had the fun I had today in a while. Spent those hours wheeling with one of my friends before he leaves out for Texas. The Dingo drove excellent as expected and made it through some place I thought for sure it'd get hung up. I figured out I can run 2+ hours on a 5000mah 2S LiPo. For those wondering, my wiring didn't short out or get hot. ALL the LEDs stayed on ALL day; even when I decided to make the truck a submarine. |
01-14-2013, 07:22 AM | #7 |
Pebble Pounder Join Date: Sep 2012 Location: Richmond
I like the wiring idea, functional.... Btw do you still need a windshield? I have one from a dingo that I never used. I just gotta find it and make sure I still have it. If I do, it's yours if you need it!
01-14-2013, 03:24 PM | #8 |
Thanks for the compliment Kykrawler! I sent you a PM about the windshield. |
01-14-2013, 04:27 PM | #9 |
Pebble Pounder Join Date: Aug 2005 Location: Monticello
Looks good. Wish I had a place like that to play.
01-14-2013, 04:33 PM | #10 |
Thanks. The park is definitely nice. Has a good mix of everything you'd possibly want to put a crawler or scaler through.
01-14-2013, 05:49 PM | #11 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
what happens when you roll over or get the light connectors wet?
01-14-2013, 07:15 PM | #12 |
FORDROX97-Nothing. I had the Dingo completely submerged about 6 times Sunday. I'd check the front just before the Dingo came back up and the LEDs were still powered up, just as bright as before. I only had to back out of the water a few times from submerged and the tail lights were still on before and after the body broke the surface of the water.
01-14-2013, 07:21 PM | #13 |
First "Scale" Accessories. Flannel Bedroll (Orange) and a simple a-frame tent (black). I'll be getting some "Scale" supports to roll in with the tent. |
01-14-2013, 09:03 PM | #14 |
Huh. I'll have to try that!
01-14-2013, 09:41 PM | #15 |
Rock Crawler Join Date: Oct 2011 Location: Canada
I don't really understand the "interesting wirirng" whats happening there? it looks like you have wires going to the body posts? explanation? wait i think i get it now. Is it like a quick disconnect? should be no issues with water, it's a very low voltage, It's not going to arc. Unless your into some high turbidity (silty) water. Last edited by Arctic Fire; 01-15-2013 at 04:06 AM. |
01-15-2013, 09:25 AM | #16 | |
| Re: Rcpilotjr's Dingo Quote:
01-21-2013, 07:51 AM | #17 |
Just a few shots from wheelin' again yesterday. Tried out my new iPhone as the camera. |
03-01-2013, 09:39 PM | #18 |
I've been enjoying my Dingo so much I forget to post.... LOL! A few weeks ago my no name motor started going bad. Dropped in an old Team Orion Core 27t and its been running like a champ since. Here it is with some new Axial 8 Hole Beadlocks and a fresh paint job. I'm really liking the red over the green. Also, broke my first part last weekend. Hit to steep of an incline and rolled end over end off of a ~12 ft. slope at probably a 65 degree angle. Only broke one of the front steering knuckles. That is a friend's WIP Dingo in front of me painted in olive drab. Last edited by rcpilotjr; 03-01-2013 at 09:41 PM. |
03-01-2013, 09:45 PM | #19 |
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
Spreading some Dingo love!
04-03-2013, 07:21 PM | #20 |
And pictures... GO! Last edited by rcpilotjr; 04-03-2013 at 07:25 PM. |
Rcpilotjr's Dingo - Similar Threads | ||||
my new dingo :) | giviko | Axial SCX-10 | 5 | 02-19-2012 11:21 AM |
another dingo | stanmondz | Axial SCX-10 | 2 | 02-14-2012 05:52 AM |
Dingo tr | koch131 | Axial SCX-10 | 0 | 03-20-2011 10:15 AM |
