01-08-2013, 07:55 AM | #1 |
RCC Addict Join Date: Jun 2012 Location: Meridian,Id
| project ridgecrest axles in scx 10
here it is now im waiting on parts i got a ridgecrest off cl and tore into it to widen the scx10. |
01-08-2013, 09:34 AM | #2 |
Quarry Creeper Join Date: Oct 2012 Location: high desert CA.
| Re: project ridgecrest axles in scx 10
what skid did you use the scx? need more pics man, how did u do the links?
01-08-2013, 10:39 AM | #3 |
Quarry Creeper Join Date: Dec 2011 Location: The land of snow
| I have this done as well. It's no different then a wroncho build. 3 of your 4 links will work. The upper link that runs with the driveshaft needs a bend to clear the shaft. The lowers either use stock wraith/ridgcrest links or you can use your metal links with xr10 ends (the ends with a bend in them) I used my scx skid.
01-08-2013, 07:03 PM | #4 |
hey guys all the links sofar are stock ridgecrest or scx10 but i just got parts today all axial aluminum links and i will be making them fit ill have pics later.
01-09-2013, 10:27 PM | #5 |
here is a pic i have i used the scx center skid and stock length alum. lower links and rear stock top links just drilled a hole for mount.the front top link s are scx10 kit alum bottom links useing the hole from the nerf bar.im not sure about the front yet it still moves side to side i need to stiffen it up.but sofar i like the width. |
01-13-2013, 10:49 PM | #6 |
here it is i changed the front top links from the last photo the only issue im having now is my servo fried and i think my endpoints were wrong. |
project ridgecrest axles in scx 10 - Similar Threads | ||||
Bender's Ridgecrest - Project Backyard Basher | BENDER | Axial AX10 2nd-gen | 30 | 03-25-2013 11:11 PM |
scikosideshows ridgecrest project check it out | Scikosideshow | Axial AX10 2nd-gen | 6 | 07-14-2012 01:56 PM |
