01-14-2013, 01:09 AM | #21 |
| Re: Recommend me some Dingo upgrades for G6 use. |
01-14-2013, 01:24 AM | #22 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
As previously mentioned, lose the dig and that will relax the driveshaft angle a bit. You can still clock the rear diff up a bit more with longer upper links. It's also imperative that you get as much weight up front as you can with the Dingo. Battery mounted crossways on the frame just ahead of the tranny is the ideal spot. The Dingo's short wheelbase is not as well-balanced as the longer Honcho and tends to tip over backwards on steep inclines.
01-14-2013, 01:36 AM | #23 |
Quarry Creeper Join Date: Jan 2007 Location: Shingle Springs
Wheelbase currently sits at 12 1/8" I pushed the rear end back about 1/2". Battery will be mounted sideways in front. I just need to figure out how to mount the ESC and receiver to avoid water.
01-14-2013, 02:12 AM | #24 |
Rock Crawler Join Date: Jan 2009 Location: Boise
You can put the rx and esc in a balloon to help water proof it. I put a balloon on, zip tie, grease or silicon, then another zip tie. I have also used small plastic boxes with a notch cut for the wires and then put shoe goo on it to seal it up. Sent from my Xoom using Tapatalk 2 |
01-14-2013, 06:39 PM | #25 |
Aww bugger! I went through Harley's 3 position dig set up routine for my radio and my dig servo wouldn't stop buzzing. I tried several different servos (Futaba S3010, HiTec HS-625MG, and an old Futaba S28 ) and they were all a little wonky (except the ancient futaba S28 go figure). Then I remembered that I have my castle voltage reg set to 7.4 volts for the 7954 steering servo. So Now I need a HV standard servo if I want this dig to work. Oh well. I know you guys say to get rid of it but I already bought it and I like the idea of dig. So I'm going to try to make it work for now. Maybe I'll take it off later if making it work keeps giving me the business. lol Last edited by 65BAJA; 01-14-2013 at 07:07 PM. |
01-15-2013, 09:41 AM | #26 |
Rock Stacker Join Date: Jun 2012 Location: Backwoods,Arkansas
good lipo's,a winch, and good friends,and you can G6 a stock scx10 if ya want |
01-17-2013, 11:50 AM | #27 |
Finally got the last servo and my lights in. Now I can finnish my Dingo. I mounted a Servo winch on the front last night. This thing is gonna be sweet. I'm going to try to take it out to the rodeo grounds this weekend to get some footage.
01-18-2013, 06:12 PM | #28 |
Cooked my ESC somehow. 😡 Do I buy one local for $99 plus tax? Or order from Tower for $85 and miss wheeling this weekend?
01-18-2013, 07:20 PM | #30 |
I may just do that. There is another LHS that might have one. I'll call them in the morning.
01-18-2013, 10:40 PM | #31 | |
Newbie Join Date: Jan 2013 Location: Canada
| Re: Recommend me some Dingo upgrades for G6 use. Quote:
01-19-2013, 12:46 PM | #32 | ||
That was a joke, 7t motor is way too low turn for G6. | ||
02-05-2013, 12:37 PM | #33 |
Wheelspeed on 2s wasn't working for me so started converting it to 3s today. Set the LVC in the FXR to 9.9 volts. Now I need a Y harness or something to run the NVS off of the BEC instead of direct from the battery. Hopefully a 10A BEC will run all 3 servos and the NVS. Two of the servos (dig and winch) are hardly ever used but I now have almost all the light ports in the NVS full. I picked up a 4x2x1 project box from Radioshack to protect the ESC, BEC and the receiver. It's pretty full with everything in there. I'll put up some more pics later. |
02-05-2013, 09:02 PM | #34 |
Rock Crawler Join Date: Oct 2010 Location: Nor Cal
Some pointers I hope that might help: 1) Since you are using overdrives in the front match them in the rear or go back to stock. When you G6 the rig will be going through sometimes hours of continous driving which over under just create more drag which can cause problems in your drive train, motor, esc, etc. I know it works really well for just crawling but G6n isn't just crawling. 2) Use a good winch and learn how to use it quickly. Don't let it "drift" nothing sucks more than having a winch that isn't working properly, broken, or a pain to use or breaks in the middle of a G6. Also use a good winch line to keep you from having to fix the line. 3) Get rid of the dig, more crap to go wrong and if it isn't set properly it can cause you problem especially with the external BEC, the dig can help but not enough with the amount of problems I can give you, plus the rear driveline angles becomes too steep with it installed which will cause driveline problems and binding. 4) Keep weight out of the drive train, I know a lot of people like to have weight in their wheels/tires, yes it does help with crawling but I found that having the extra weight cause brushed motors to burn up especially when your going for miles or hours non stop. using metal axles, and keeping the weight forward and low could get the same crawling ability. 5) Batteries: have as many as you can get - the more mah the better, doesn't matter if it's 3s or 2s or whatever the size, I use small 2250mah batteries which only last about 75 to 100 gates per battery (I run the Ultra Class so the truck sometimes at full throttle for longer periods of time and 3 speed controller and 1 bec is hooked to one battery) run time can be effected by the condition your rig is in like locked up bearings, worn motor, cold weather, or even the course (ie fishing line, sand, mud, birthday cake) so even though you can get 2 hour run time at a GTG you might get a lot less during a G6. 6) Waterproofing. Do whatever you can do to waterproof your rig, everyone has the own way of doing it. Just make sure you do it (better safe than sorry) 7) I tell everyone at work that the one thing you can't buy is Skills. So pratice pratice pratice makes perfect or at least close to perfect. GTG are a great way to pratice with a scaler. These are some of the thing that came to my mind when reading your original post. I'm sure there are many that would disagree to some of my points but this is what has worked for me. See you at the next G6 Here's a video of one of my G6 Ultra ride. For any other ideas you can get from it. This is built only for RECON G6 with 2 years experience G6n. |
02-06-2013, 01:04 PM | #35 | |
02-06-2013, 02:09 PM | #36 |
05-07-2013, 09:29 PM | #37 |
So the Dingo has been together for a little while now. I went up and did the Oroville G6 with it, along with a few local G2G's. I've been using a 3s 3700 as the main battery with the 4 2500's as backup. No major problems with it. Very happy with how well it works. I have had some small problems though. The screws that hold the C hubs on to the front housing are kinda stripped and the shocks leak oil like a sieve. For the axle problem I think a Currie housing may be in my future. They just look so cool. For the shocks I installed a set of Revo GTR shocks with yellow Jato front springs. The rate on the yellow springs (4lb/in)are about the same as stock but even with the #1 pistons (biggest hole) and only 15wt oil the dampening is way too stiff. The #1 pistons are supposed to be 1.0 mm I think. I think I will try to drill them out to 1.58 mm (1/16"). I might have to go back up on the oil wt at that point though. We will see. I would post current pics but my star died and I'm saving my scrilla for Cisco Grove/Axial Fest 2013 tickets. So the star will have to wait. |
05-07-2013, 10:33 PM | #38 |
Pebble Pounder Join Date: Mar 2013 Location: Honolulu
Idk why people are telling you to ditch the dig? IMO that is the best thing you can run when trying to make all the gates with tight turns. The hurts dig is top shelf stuff. It shouldn't give you any problems. I take mine apart and cleans and lube it about every 3-5 packs. As far as your rig. Definetly need to improve your rear driveshaft angle like others said above. If you're going to ditch anything, ditch that front 3 link and install a 4 link. I'd also get some wider hex's up front. Your tire is too close to the knuckle arm and will get literally wrapped up on the thing. Also agree with shaving the bumper. Edit: I didn't even see that there was a second page to this thread when I wrote this! You've probably squared away all this stuff already! Lol Last edited by cox308; 05-07-2013 at 10:36 PM. |
05-07-2013, 11:00 PM | #39 |
Quarry Creeper Join Date: Apr 2012 Location: San Jose, CA
05-07-2013, 11:33 PM | #40 | |
Recommend me some Dingo upgrades for G6 use. - Similar Threads | ||||
Upgrades on my Dingo | B94Cast | Axial SCX-10 | 12 | 11-18-2012 02:40 PM |
upgrades to consider while building dingo? | traxxascrazy56 | Axial SCX-10 | 35 | 10-21-2012 02:25 PM |
