01-12-2013, 10:07 AM | #1 |
Newbie Join Date: Jan 2013 Location: Knoxville
| Brand new SCX-10 with leaking shocks
Is this a common issue with these trucks. I just purchased 1 and the shocks are leaking.
01-12-2013, 10:20 AM | #2 |
Quarry Creeper Join Date: Mar 2009 Location: Independence,KY
| Re: Brand new SCX-10 with leaking shocks
Mines maybe 3 weeks old and one of mine are leaking, right rear to be exact not that it matters
01-12-2013, 10:25 AM | #3 |
All rc shocks leak to a certain degree, manufacturer and build techniques play a part though. Grab some associated green slime during your next visit to your lhs, apply lovingly to bottom cartridge and top cap during your next shock rebuild. The grease barrier helps hold the shock oil in.
01-12-2013, 10:39 AM | #4 |
I actually picked up some green slime but all of my shocks are leaking, one really bad.
01-12-2013, 10:49 AM | #5 |
I would email Axial support and let them know about the problem with your shocks. The o-rings in the shocks need to be replaced and the shocks refilled with oil. Rebuilding shocks is a skill that you need to learn to maintain your crawler. There are various threads and videos on how to do this. If properly assembled, the SCX10 shocks do a good job and don't require frequent oil refills. |
01-12-2013, 12:32 PM | #6 |
Newbie Join Date: Dec 2012 Location: Winnipeg, Manitoba
Mine leak too, its not bad at all though, I don't think Ive ever had a shock that completely never leaked.
01-12-2013, 12:39 PM | #7 |
Pebble Pounder Join Date: Nov 2009 Location: Waterford , PA.
I just put together a Dingo kit and my shocks are leaking more than normal. I used green slime on the shafts and o-rings. I read somewhere to use Traxxas o-rings in them. I am going to try that. |
01-12-2013, 04:26 PM | #8 |
Sad fact, no matter what you do with them the SCX stock shocks will not hold oil worth a darn. Sure, all RC shocks will "seep" to a certain degree. The stock SCX shocks straight up leak badly compared to most others. I assembled mine with appropriate use of Green slime and teflon tape only to have three of them practically empty after three packs. Rubbish I say. |
01-12-2013, 05:13 PM | #9 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
I put traxxas o rings in mine. They are a little big, so I only put one on the bottom. Haven't leaked much. I'll try some of that ae grease.
01-12-2013, 09:40 PM | #10 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Invest some money in some aftermarket shocks Traxxas BigBores are leakproof ...I have 5 sets on 5 different trucks...not one leaks even a tiny bit...spring options are all over the map for all kinds of situations....best investment ever |
01-12-2013, 10:38 PM | #11 |
Pebble Pounder Join Date: Sep 2005 Location: Citrus Heights, CA
Postclanker is right on with the traxxas big bores, I have had a set of them and never had a tiny bit of leaking and i've been running them for 6 years now
01-13-2013, 09:32 AM | #12 |
Newbie Join Date: Dec 2010 Location: Greenfield
Bought my Honcho new, as soon as I removed it from it's original package, I noticed the front right shock had leaked all the oil out. Plan on replacing them anyways.
01-13-2013, 09:38 PM | #13 |
Rock Stacker Join Date: Dec 2012 Location: Fremont
One of mine is leaking bad. They seem really cheap and I want some good shocks that aren't too expensive, I been looking a Prolines- anybody have them?
01-13-2013, 10:06 PM | #14 |
| Re: Brand new SCX-10 with leaking shocks Are you using Traxxas springs or another brand of spring on the bigbore shocks ?
01-13-2013, 11:26 PM | #15 | |
Quarry Creeper Join Date: Mar 2012 Location: Roseburg
Sent from my Transformer using Tapatalk 2 | |
01-13-2013, 11:41 PM | #16 |
| Re: Brand new SCX-10 with leaking shocks Not a great picture....but I use the red springs in this rig An example of the losi mini spring....fits nice and works great Another example of another losi spring....inverse shock position and a little bigger spring... I use the red stock spring in my wraith as well. My Wreckluse and wraith are fairly heavy rigs...so the stock red springs work well for those. The scx10 is roughly 6.5 lbs and the losi springs work exceptionally for that rig. The Mantis/XR10 is a bit heavier...but it's a strange beast and liked the special losi springs I found that fit and work very well. Bottom line is finding what works for your rig. If your rigid lighter 5-7 LBS use the Losi mini springs...any heavier ..Try the red stock springs, or something else a little stiffer Best of luck Nitro |
01-14-2013, 03:49 AM | #17 |
Thanks for all the replies. I know how to rebuild shocks. I was just inquiring as to whether anyone else was having an issue out of the box with the axials Sent from my SAMSUNG-SGH-I317 using Tapatalk 2 |
10-22-2013, 05:16 AM | #18 |
Pebble Pounder Join Date: Jul 2013 Location: England
Hope this helps those with leaking SCX10 shocks: A month after replacing the Axial O-rings on my SCX10 Rubicon with "Tamiya 50597 Damper O-rings (10pcs)." the results are in... In summary the Tamiya O-rings make a big difference to the rate of oil loss from the dampers. They are not a perfect 100% leak free fix, but a huge improvement for a low cost. However they are tricky to install. Here is a video on the leaks, the new orings and the results: 4WheelRCUK - Axial SCX10 Leaking Shocks Solved (80%). - YouTube Thanks to 'BigGaz' on the ModelSport UK forum for suggesting the Tamiya 50597 O-rings |
10-22-2013, 06:57 AM | #19 |
Since 4wheelrc bumped this thread I'll add this: Tech Thread -- SCX10 shocks |
11-11-2013, 04:04 AM | #20 |
Quarry Creeper Join Date: Aug 2011 Location: United Kingdom
Anyone notice if the new icon shocks leak more or less than the plastic oil variants? Sorry, but I have not been on here for a year and don't have the time to search much :( Looking for reasons to go for the kit over the rtr as I sold my dingo earlier this year... |
Brand new SCX-10 with leaking shocks - Similar Threads | ||||
all 4 shocks are leaking | m1009cucv | Tamiya XC/CC01 | 7 | 02-27-2011 10:13 AM |
My shocks are leaking. | EZap | Redcat Crawlers | 6 | 05-07-2010 11:05 PM |
Leaking shocks? | Synister_Intent | Losi Mini-Rock Crawler | 17 | 04-05-2010 07:34 PM |
Leaking shocks....???? | Ritter1 | Team Losi Comp Crawler | 4 | 08-14-2009 02:28 PM |
Brand new ARTR shocks leaking?? | VeryBumpy | Axial AX-10 Scorpion | 8 | 04-06-2009 02:07 PM |
