01-14-2013, 05:16 AM | #1 |
Newbie Join Date: Jan 2013 Location: North Haledon
| Exposed gears with mirrored tranny in dirt/mud?
Ok I am doing my first scx build with a Dingo and trying to decide whether I want to mirror the tranny or not. The only con I see is that you cannot run the cover. I plan on waterproofing the electronics so I can run through water and mud. Is this going to be a issue with the exposed gears? I have done a ton of searches and have not seen this addressed. Thanks in advance! |
01-14-2013, 05:37 AM | #2 |
Rock Stacker Join Date: Aug 2012 Location: mchenry
I don't think it will be an issue. I run the same set up in mud snow dirt. As long as you keep it clean after runs should be fine.
01-14-2013, 05:42 AM | #3 |
| Re: Exposed gears with mirrored tranny in dirt/mud?
Really? I just see some crap getting in there and chewing up the plastic gear. I might have to see if I can make up a backing plate for the cover. |
01-14-2013, 05:52 AM | #4 |
I thought the same. But 3yr with 2 scx's no gear covers only thing I've got caught has Ben few leafs and twigs. No premature gear wear. I only see an issue if your in mud up to the spur.
01-14-2013, 07:28 AM | #5 |
I've never run a gear cover and with 3 mirror imaged trans haven't had an issue. Going 32p would possibly help you sleep better at night.
01-14-2013, 11:27 AM | #6 |
Hmm interesting well I guess I can give it a try. Whats the worst that can happen? replace a plastic gear? Thanks guys. |
01-14-2013, 11:32 AM | #7 |
Rock Crawler Join Date: Mar 2012 Location: UK, Hampshire
i've run the same transmission without a cover in my scx10 for 3 years and only had replace the idler gear 4 months ago, still running the stock bottom plastic gear and metal top gear, i run my truck in sand, mud, water, and when i take it apart it's spotless, absolutely minimal dirt and grit inside that will cause no damage to the plastic gears, just make sure the gears are properly greased. i mirrored it also. i am even running the same plastic spur, these trucks are very tough when treated correctly. . Last edited by pobrockcrawler; 01-14-2013 at 12:40 PM. |
01-14-2013, 12:24 PM | #8 |
Ok well guess I will switch it back again! I put it together stock and just rotated the skid, then I decided to mirror the trans and realized the cover didnt fit. Did a bunch of research and found out you dont use it, wrote this thread, then switched it back to stock. Now I guess I will pull it back out and switch it again. What is everyone using for spacers? Or did you just cut up the stock cover? |
01-14-2013, 01:35 PM | #9 |
Rock Crawler Join Date: Nov 2010 Location: south prairie
Do you mean the spacers between the tranny case and motor plate? If so, I think they should've came with your kit on one of the parts trees. Sent from my PC36100 |
01-14-2013, 02:32 PM | #10 |
Oh yeah? I am still assembling so I will have to look through my parts. Thanks! |
01-16-2013, 09:04 PM | #11 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
Yeah, just rotate the skid. That gets the motor on the right side and you can still use the gear cover. Best of both worlds.
01-16-2013, 09:12 PM | #12 |
Motor to the passenger side is only part of it, getting it front side of the skid is the other.
Exposed gears with mirrored tranny in dirt/mud? - Similar Threads | ||||
mirrored tranny | will1978 | Axial AX-10 Scorpion | 12 | 11-11-2010 11:23 AM |
Mirrored tranny and DIG | RickM | Axial AX-10 Scorpion | 13 | 03-02-2010 09:04 PM |
bender with mirrored tranny and vanquish dig? | slc4me | Axial AX-10 Scorpion | 10 | 12-11-2009 06:22 PM |
My Mirrored tranny is wumming?! | treeafodo | Axial AX-10 Scorpion | 2 | 10-28-2008 08:12 AM |
best 2.2 tire for dirt/mud? | swamp_rat | Tires and Wheels | 10 | 06-27-2006 12:31 PM |
