01-17-2013, 03:50 PM | #1 |
Newbie Join Date: Jan 2013 Location: Australia
| SCX10 Honcho Vanquish upgrade question
Hi all, I'm new to scale/crawling and was wondering if someone could assist me a bit with this. I've been looking online a lot but couldn't find exactly what I'm after. Basically, I'd like to upgrade my whole driveline and steering and I do have a rough idea what I need but I'm not entirely sure which parts I need exactly and I really don't want to order something and then realise that I forgot to order something so I have to wait some more. I hope you understand. So, RC car is SCX-10 Honcho. So far everything on it is stock. Here is what I think I need, please add/subtract something I got wrong or missing please: I'd like to get these axle housings for front and rear, but VP seems to have this one only: Unless front/rear are the same? Are they? Apart from axle housing I think I also need: - Axial scx10 chubs 8 degree - Axial SCX-10 universal cvd , honcho, VVD Heavy Duty Axle Shafts - Axial SCX10 8 degree knuckles - Axial SCX10 Axle Lockouts for AX10, Honcho - TITANIUM LINKS ??? (do I need Vanquish links? plan to run 4-link setup) - RC Gear Grease Is this all I need? Any suggestions? Since Vanquish doesn't have drive shafts for SCX Honcho, would above setup run OK with stock drive shafts or Punisher drive shaft. I imagine this would run fine with Vanquish parts above? Many thanks peeps Any input greatly appreciated Sincere apologies for extensive writing. igz Last edited by igz; 01-17-2013 at 03:53 PM. Reason: link added |
01-17-2013, 03:59 PM | #2 |
Newbie Join Date: Jun 2011 Location: Australia
| Re: SCX10 Honcho Vanquish upgrade question
theres a stage 1 kit which will be your best bet... but up to u... so far u got everything uneed... grease i wouldnt bother... you may want to buy the overdrive kit from rpp... if your full on serious... do u still wanna compete? pretty sure they have the same regulations as in here (Australia) |
01-17-2013, 05:13 PM | #3 |
Thanks mate, I really appreciate it. Yes, stage 1 kit option I fully missed. Thank you. Sorry, which overdrive kit from RPP is this? Can I do wihout it or...? Many thanx mate |
01-17-2013, 05:29 PM | #4 |
Pebble Pounder Join Date: Jun 2011 Location: Sonoma, Ca
The axle housing works for both front and rear axles so you will need 2 of them. As for the other parts I will make you a list. Axial AX10 stage 1 kit this is a set and it will save you money. it includes knuckles C-hubs and Lockouts X1 Vanquish AX-10 Shock Link Mounts this is for lower links and shocks X2 Vanquish AX-10 Axle Servo Mount servo mount you will not need this if you are running a chassis mounted servo X1 Vanquish AX-10 Axle Truss truss/ upper link mount (4-link) X2 you will need 2 diff covers, and there are two styles Vanquish AX-10 Axle Truss and Axial Wraith Differential cover diff Axial Wraith Bearing Caps Ridgecrest holds the locker's bearings in Currie/SCX Titanium tie rod / drag link Tie-rod and drag link this will fit with the VP Knuckles. if you have any question PM me. |
01-17-2013, 06:00 PM | #5 |
Holy cow your Honcho looks sweet! First off - THANK YOU! Just one question please: Do I need Vanquish titanium links too: ? Many thanks mate, I appreciate it. Also, if you have a link with more pics of your Honcho, pls send, I'd love to see it as it's very hard to find pics with Honcho Vanquish driveline setup. Cheers mate igz |
01-17-2013, 07:42 PM | #6 |
Rock Crawler Join Date: Oct 2010 Location: Nor Cal
Stay a way from the punisher drive line, they are horrible. For drive line right now I would go with MIP for the scx-10. The axle housing you're looking at is the same for the front and the rear. |
01-17-2013, 08:58 PM | #7 |
Another example of the axles you're interested in. I did something a little different up front though, I'm running a CMS (chassis mounted servo) rather than the servo on axle. Good Luck on you build. |
01-17-2013, 09:34 PM | #8 | |
| Re: SCX10 Honcho Vanquish upgrade question Quote:
I like this style SCX axles and nicely done Mike as usual. | |
01-18-2013, 05:06 PM | #9 |
| Re: SCX10 Honcho Vanquish upgrade question Nice rig i saw this all over the G6 facebook page. Our honchos almost look identical in certain ways and im also running a CMS, is yours the JR battery mount/cms?
01-18-2013, 05:41 PM | #10 |
| Re: SCX10 Honcho Vanquish upgrade question Thanks, the Honcho has been to many different G6. I am running a modified Hands Brother cms kit originally for the stock plastic scx-10 axles.
08-20-2013, 07:38 PM | #11 |
Pebble Pounder Join Date: Jan 2013 Location: Quebec, Qc, Canada
| Re: SCX10 Honcho Vanquish upgrade question Super sweet dude . I thought about getting fully decked out Vanquish axles but there is one piece that I really just can’t decide in which colour to get. Originally, I wanted to get all blacked-out axles but I just see them getting scratched-up too fast. Your setup looks cool (raw aluminum axle housings), does it continue looking good after a lot of wear? The only thing really holding me back from getting black axle housings is the raw aluminum showing when it gets scratched. So should I get black axle housings or raw ones?
SCX10 Honcho Vanquish upgrade question - Similar Threads | ||||
SCX10 Honcho question | gambler | Axial SCX-10 | 14 | 01-18-2013 04:02 PM |
hey guy's question on the scx10 honcho trail ready | tundrafan01 | Axial SCX-10 | 8 | 09-12-2011 10:45 PM |
Scx10 Honcho Battery question? | PontiacGT201 | Electronics | 2 | 09-15-2010 10:11 PM |
Vanquish Products new SCX10/Honcho Shock Hoops | Nicklovin | Axial SCX-10 | 27 | 09-02-2010 06:52 AM |
