01-24-2013, 05:42 PM | #1 |
| eric113's 2nd portal Mog Current Setup Front Axle Hot racing spool 3racing portal Traxxas bearings Traxxas stub shafts Gunnar custom pins Custom steering links Axial Cvd's Dynamite alum servo horn Axial clockable C's Axial HD 36/13 gears Rear Axle Axial HD stock gears Hot racing spool 3racing lock out 3racing portal Traxxas bearings Traxxas stub shafts Gunnar custom pins Axial 4 link mount Axial stock inner shafts Rolling Stock Rc4wd Hummer wheels Proline 1.9 super swamper tires Transmission Robinson Racing Idler Gear Highlandcrawler steel pinned outputs BWD motor plate 16 tooth 48 pitch Robinson Racing pinion 80 tooth 48 pitch kimbrought Spur Gear Driveshafts Axial driveshafts Suspension RJ2 stainless steel links tapped 10-24 Traxxas revo rod ends Proline scale shocks - 50wt oil Rear 3racing MLST 66mm shocks- 60wt oil Chassis and Body Axial Scx10 chassis Hand Bro's Scx10 Cms kit Rc bros servo clamps Dinky tube work Home made front bumper RC Screwz stainless steel screws Tamiya Unimog 406 cab Fattbatt electronics/winch tray Power and Control Holmes hobbies Br-xl Holmes hobbies torque master pro 25t Futaba S9156 steering servo Futaba 4PK Futaba R604FS RX Towerpro servo winch Heyok HV winch controller 800mah 40c & 1300mah 40c 4s sky lipos |
01-24-2013, 05:46 PM | #2 |
| Re: eric113's 2nd Mog
Dezfan parted out his mog and I was able to snag body set. First things first get the work bench cleaned up and parts ordered. Next... Mocking it up to see what needing to be modified. Also threw on the new parts. |
01-25-2013, 05:33 AM | #3 |
Rock Stacker Join Date: Jan 2013 Location: Ohio
| Re: eric113's 2nd portal Mog
This is the first build where I have noticed the portals being available! I look forward to watching the rest of your build. I am starting to get the bug for a Mog.
01-25-2013, 06:20 AM | #4 |
| Re: eric113's 2nd portal Mog Thanks, but unfortunately 3racing stop making the portals. I did work on it lastnight. But hit a stopping point. I need to order hardware and links. Then figure out eletricronics placement.
01-25-2013, 07:22 AM | #5 |
RCC Addict Join Date: Jan 2006 Location: The "Hive"
I was wondering where this thing went... Glad to see it in good hands! And with Portals! Nice! |
01-25-2013, 07:39 AM | #6 |
Quarry Creeper Join Date: Oct 2010 Location: Hendersonville
No more Portals? Is this true? Anywhere? Such an awesome axle mod to not have someone manufacturing them!
01-25-2013, 10:35 AM | #7 | |
| Re: eric113's 2nd portal Mog Quote:
Me and Chino been looking everywhere for them and turned up nada. When I bought mog, I was lucky enough Dez also had a set of portals also! | |
01-25-2013, 10:37 AM | #8 |
Take good care of my baby.
01-25-2013, 01:59 PM | #9 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
I got DIBS Eric. I don't know how I missed the FS add, maybe a FS mod sniped it? Looking good Eric. |
01-25-2013, 02:02 PM | #10 |
| Re: eric113's 2nd portal Mog |
01-25-2013, 04:28 PM | #11 |
| Well that would be why I haven't seen them. I've only been at this two weeks. Now, I am very jealous.
03-22-2013, 10:00 PM | #12 | |
You got seconds Sheldon! I got first return dibs! How's my baby Eric, any updates? I sometimes regret selling her, but then I get to go to the range, send some lead down range, and it makes it all worth while. You should sent it home to visit every once in a while. | |
eric113's 2nd portal Mog - Similar Threads | ||||
eric113's Mog | eric113 | Axial SCX-10 | 109 | 04-07-2022 07:52 AM |
eric113's FJ tuber | eric113 | Axial SCX-10 | 14 | 02-15-2011 10:52 PM |
eric113's Xr10 | eric113 | Axial XR10 | 43 | 10-21-2010 07:38 AM |
eric113's Honcho | eric113 | Axial SCX-10 | 44 | 05-06-2010 09:36 PM |
