01-27-2013, 08:15 AM | #1 |
Rock Stacker Join Date: Apr 2011 Location: bergan
| Axial links with Vanquish Currie Axles
I wanted to know if I would be able to use the axial links with the currie axles because I have the axial orange links and I dont want to get rid of them. I saw on vanquish's website that you need to use their links with the axles. Is this true or will the axial links work? Thanks! |
02-20-2013, 05:13 AM | #2 |
Newbie Join Date: Feb 2013 Location: Australia
| Re: Axial links with Vanquish Currie Axles
As you know, they say you can't, but i would also like to know why? Surely they can be made as with the scx10 links?
02-20-2013, 06:50 AM | #3 |
Rock Crawler Join Date: Jan 2010 Location: In the lair editing video
front uppers have a bend in them to clear the bottom of the chassis, also the lengths are pretty different. The 4 link mount on the Currie axle is quite a bit higher up than the mounting point on the stock axle. You can make your own links for sure, but the stockers won't fit. |
02-20-2013, 07:18 AM | #4 |
Quarry Creeper Join Date: Dec 2010 Location: Alberta
You can use your lowers but not the uppers. On a stock SCX10 the bottom links are longer then the top. With the curries the top link is longer then the bottom. If you used the stock uppers it would clock the back of the diffs down for horrible driveshaft angles and less clearance.
02-20-2013, 04:20 PM | #5 |
Thanks for the input guys! Now the big decision, these or a Vaterra Twin Hammer......
02-20-2013, 05:54 PM | #6 |
Well that stinks looks like vanquish has to make colored links!
Axial links with Vanquish Currie Axles - Similar Threads | ||||
Badger's Axial SCX10 Jeep JK w/ VP Currie Rock Axles | badger | Axial SCX-10 | 283 | 01-23-2016 08:04 PM |
Vanquish SCX10 Currie Axles IN Stock | RPP Hobby | RPP Hobby | 2 | 03-26-2015 07:54 PM |
FOFF Whiplash on Vanquish Currie axles | 1tonscout | Formula Offroad | 34 | 07-18-2013 06:44 PM |
New Vaquish Axles - Thank you Currie | bigstu | General Scale Talk | 60 | 12-11-2012 06:04 AM |
