01-30-2013, 07:53 PM | #1 |
Newbie Join Date: Oct 2010 Location: Griswold
| Double dig bolt on?
Just like the subject said... I'm considering putting a dig unit one on each side of transmission to have "atlas transfer case function"... I was wondering if Anyone have done it yet? Any comments welcome! Sent from my DROID RAZR using Tapatalk 2 |
01-30-2013, 08:04 PM | #2 |
Rock Stacker Join Date: Dec 2012 Location: Staley NC
| Re: Double dig bolt on?
I was wondering the same thing or is it even worth having??
01-30-2013, 08:06 PM | #3 |
RCC Addict Join Date: Nov 2006 Location: burlington
I am doing this with my new C3 scaler, and using VP digs for this. there is a little shaving on the trans and dig to make it work. you also loose the upper bolt mount on the added dig.
01-30-2013, 09:14 PM | #4 | |
I'm thinking about going Vanquish or eritex dig if eritex is still around (haven't checked) About your vp dig do the output shaft moves in and out of dig as you change position? Like my dna dig does Sent from my DROID RAZR using Tapatalk 2 | |
01-31-2013, 11:56 AM | #5 |
on the VP the output does not move in and out. here is what I shaved off. you can see only one bolt hole lines up and you loose the upper one. but it wouldn't be hard to make a plate to catch that upper bolt hole. the hole that is off is not by much either. |
01-31-2013, 12:49 PM | #6 | |
Rock Crawler Join Date: Apr 2010 Location: Kelowna, B.C., Canada
| Re: Double dig bolt on? Quote:
Also rc4wd makes a version of the r2 transmission that has dig front and rear. R2 Dual DIG Tranny Black | |
01-31-2013, 01:13 PM | #7 | |
ya, it will be used as a transfer case. I have a Dinky GR7 to run it. I have ran about every dig out there and none have compared to the VP. | |
01-31-2013, 03:00 PM | #8 | |
I'm not sure how u plan on using gr7 with double dig unless u are planning on using axial trans on center skid then wouldnt the gcm front motor/trans mount for scx10 work better? I'm just wondering how u plan to get it all work together Last edited by Nocturnalsixer; 01-31-2013 at 03:05 PM. | |
Double dig bolt on? - Similar Threads | ||||
Hot racing bolt on DIG. | thrash_16 | Axial AX-10 Scorpion | 0 | 09-07-2010 03:03 PM |
is there a bolt on DIG 4 SCX10's??? | yellowpasta2000 | Axial SCX-10 | 20 | 11-26-2009 03:09 PM |
Double dig tranny? | mmbackpacker | General Crawlers | 5 | 01-19-2009 03:11 PM |
Bolt on dig coming soon | Joat | Tamiya CR-01 | 4 | 12-07-2008 09:05 PM |
