01-31-2013, 06:27 PM | #1 |
Newbie Join Date: Dec 2012 Location: Saskatchewan Canada
| axle mount VS. chassis mount servo
after reading thru several other threads i cant really find the answer to my question. What are the advantages/disadvantages of one over the other? Thanks Mike |
01-31-2013, 06:37 PM | #2 |
Newbie Join Date: Oct 2012 Location: Flint
| Re: axle mount VS. chassis mount servo
A more scale look.
01-31-2013, 06:46 PM | #3 |
agreed...... but does one perform better over the other?
01-31-2013, 06:53 PM | #4 |
Rock Stacker Join Date: Jan 2012 Location: Fuquay Varina
I think that you get better articulation with it on axle. It does give up the scale look as you both said.
01-31-2013, 06:53 PM | #5 |
i would say no
01-31-2013, 07:41 PM | #6 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
axle gives you better performance Chassis give you bump steering sometimes when the suspension travels it effects the steering, usually only noticeable at higher speeds. chassis gives you more scale look taking it out of view keeps it up higher to keep it out of moisture |
01-31-2013, 07:46 PM | #7 |
When set up correctly there is no difference in performance.
01-31-2013, 08:08 PM | #8 |
RCC Addict Join Date: Oct 2005 Location: rite here all along
On the axle gives better performance, look at the 1:1 world with full hydro steering and the cyls are mounted on the axle cms looks more scale for the average full bodied scale truck. If properly set up cam's was just as efficient as on axle steering it would be Jed on 2.2 comp rigs and supers |
01-31-2013, 08:13 PM | #9 |
Quarry Creeper Join Date: Mar 2011 Location: columbus
I run my traxxas servo on the axle. Never had an issue stripping gears. However, it's better to use the plastic turning links because its gives a little under tension
01-31-2013, 08:25 PM | #10 |
And what exactly is the purpose of the panhard bar? i see alot of CMS setups using it and wonder why.
01-31-2013, 09:12 PM | #11 |
| Re: axle mount VS. chassis mount servo |
02-01-2013, 04:25 PM | #12 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
02-01-2013, 04:52 PM | #13 |
thanks guys. I think for now i'm gonna leave it on the axle. im piecing together the parts for another scx and i think i will try a CMS on it and see which one i like better |
02-01-2013, 05:25 PM | #14 |
Rock Crawler Join Date: Jan 2012 Location: Champlin, MN
Higher weight make it slightly more top heavy. although with a proper set up the function is identical. Benefits of body mount is more to do with scale appearance.
02-01-2013, 05:30 PM | #15 |
02-02-2013, 12:59 AM | #16 |
Newbie Join Date: Aug 2012 Location: Portland
For most of the crawling I've done, the cms doesn't seem to limit me from anything other then body placement. On my tj build I has to move the body around to cover the servo. |
02-02-2013, 07:46 AM | #17 |
07-20-2016, 09:42 AM | #18 |
Newbie Join Date: May 2015 Location: San Diego
I don't like the chassis mount stlye because the whole front end does offset when you cycle the suspension
07-20-2016, 12:50 PM | #19 | |
Quarry Creeper Join Date: Jan 2014 Location: Ukiah
| Re: axle mount VS. chassis mount servo Quote:
That's very minimal as most of the weight (electronics, battery, motor and trans) is located on the chassis anyway. Yes, it may help a lil but not very noticeable compared to a CMS setup Sent from my iPhone using Tapatalk | |
07-20-2016, 01:05 PM | #20 |
RCC Addict Join Date: Apr 2011 Location: San Diego
Chassis mount for me. Offset during cycling should be minimal if you have it set up properly. Axle mount is definitely more straight forward and don't have to worry about links hitting anything, but you do have to make sure theres room for the servo to cycle with the axle. I typically like my battery up front so this method prevents me from doing that. |
axle mount VS. chassis mount servo - Similar Threads | ||||
BWD Modular Servo Mount/Battery Tray/Adjustable Upper Link Mount | billet works | HPI Wheely King | 18 | 07-05-2010 10:52 AM |
Who makes a servo mount for a txt to mount it on the axle | robster | Tamiya Txt-1 and Juggernaut | 1 | 12-14-2008 05:50 PM |
