10-26-2015, 06:09 PM | #1 |
Newbie Join Date: Oct 2015 Location: Charlestown
| Pro-Line ridgeline bumper installation issues I received the pro-line bumper set in the mail today and was excited to install it. I expected a quick, 5 minute screw a few things together kind of install but I ran into a few issues. First it came with no instructions so I had search online for some. ok fine. Then the mounting legs or whatever you call them are too long but that's no big deal either. I can just cut them. The bigger issues I have are: 1. There is no way to mount the rear bumper, at least on my deadbolt. It looks like I have to buy a whole spare scx10 rear bumper kit just for the mount. This would not have been quite as big a deal (though still annoying) if I had known about it before so I could have bought the extra bumper at the same time. 2. The screws to the legs don't work because the holes are too big. I can't secure the mounting legs to the bumper adapter plate because the screws don't hook up. They are the correct screws, 3x12mm. I don't think I have any other screws that would work so I may just try hot gluing the screws in place. |
10-27-2015, 06:47 AM | #2 |
Pebble Pounder Join Date: Feb 2015 Location: in my house
| Re: Pro-Line ridgeline bumper installation issues
I had these same problems with mine. What I did was buy a cheap $10 aluminum bumper mount from hot racing for the front, and I moved the front bumper mount to the rear. This made the front a lot stronger. For the screws that won't fit into the mounting pegs, what I did was drill a larger hole into the mounting pegs, and then used the thick screws that the bumper kit came with (I think they are for the Revo). they fit in there with the larger diameter hole without splitting the plastic.
10-27-2015, 04:13 PM | #3 |
I found some screws which worked OK for the legs. They're a bit short and may loosen up after getting bumped around later but are fine for now. Also ordered an axial rear bumper set for $12. It looks the same as what I have but with the leg holes so it should work. |
10-28-2015, 01:26 PM | #4 |
Newbie Join Date: Nov 2007 Location: Brownsboro
Thanks for the heads up, I was looking at getting these bumpers.
10-28-2015, 07:14 PM | #5 | |
| Re: Pro-Line ridgeline bumper installation issues Quote:
now just waiting on the rear bumper... hopefully friday. | |
12-20-2016, 08:50 PM | #6 |
Newbie Join Date: Dec 2014 Location: Northern Ca
Man, thanks for the heads up. I'm tryin to decide on which frt & rear bunpers & DON'T EVEN want to go down this road. Been there done that! Shame on Pro-Line for puttin out a "not so complete" product. When i buy an aftermarket accessory / part i expect it to fit & don't mind payin extra for a complete compatible product that doesn't require modification. |
12-22-2016, 09:07 AM | #7 | |
RCC Addict Join Date: Jan 2007 Location: Arkansas
Pro-Line ridgeline bumper installation issues - Similar Threads | ||||
Pro-Line F250 Half Cab bumper options? | JDeezie82 | Axial SCX-10 | 4 | 12-13-2013 05:27 PM |
