02-02-2013, 12:14 PM | #1 |
Newbie Join Date: Dec 2012 Location: Paducah Ky.. / Western KY.
| Pros vs. cons ?
I looking to buy and install both front pan hard bar kit and rear shock location kit. Before so didn't know if anyone had them already and had any PROS or CONS to them so I know what I'm facing .. Any input will be helpful and appreciated . Thanks |
02-02-2013, 12:16 PM | #2 |
Quarry Creeper Join Date: Mar 2012 Location: Roseburg
Are you running a CMS? If not, the panhard bar is only going to look shiny and add weight. If so, it will help keep proper location of the axle and reduce bump steer. |
02-02-2013, 12:18 PM | #3 |
| Re: Pros vs. cons ?
Sorry new to the terms. Lol . Cms?
02-02-2013, 12:20 PM | #4 |
Newbie Join Date: Dec 2012 Location: Saskatchewan Canada
| Re: Pros vs. cons ?
CMS = Chassis Mounted Servo
02-02-2013, 12:23 PM | #5 |
Pebble Pounder Join Date: Dec 2010 Location: Fresno
| Re: Pros vs. cons ? |
02-02-2013, 12:27 PM | #6 |
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
| Re: Pros vs. cons ?
Are you referring to angling your shocks forwards/inwards? The pro is that you will get more wheel travel per given distance of shock travel. The con is that if you are happy with the amount of travel you have now, you will need a shorter shock or bumpstops and some fine tuning to keep that same amount after angling them. Changing this ratio of wheel travel/shock travel also effects the spring rate. If you are happy with the stiffness you have now, an angled shock will require a bit higher spring rate to maintain the same stiffness.
02-02-2013, 12:39 PM | #7 |
02-02-2013, 12:50 PM | #8 |
| Re: Pros vs. cons ?
I am going to a CMS it's part of the kit I found , and as far as the shocks I believe is ckrccrawlers that now has a shock relocation kit that moves the top shock mount to the inside of the frame . Near center. What I have now is ok . But was wanting to know if it had more of a performance benefit than a looks kinda thing.
02-02-2013, 01:56 PM | #9 |
02-02-2013, 03:13 PM | #10 | |
| Re: Pros vs. cons ? Quote:
Pros vs. cons ? - Similar Threads | ||||
pros-cons honcho | Toyoty | Axial SCX-10 | 5 | 06-21-2012 05:43 AM |
Pros and Cons | wardal | General Crawlers | 1 | 11-21-2011 06:20 PM |
Pros and Cons | Iberian | Newbie General | 20 | 01-13-2010 07:22 PM |
MOA Pros and Cons | Iberian | Team Losi Comp Crawler | 19 | 12-30-2009 10:13 PM |
Pros and Cons of 50/50 to 60/40 | zboarder720 | Newbie General | 5 | 05-14-2006 10:13 PM |
