Thread: Vanquish Zero Aker Kuckles
Old 02-03-2013, 05:04 PM   #1
Default Vanquish Zero Aker Kuckles
I just ruined a aluminum HR knuckle on my SCX10 and I'm looking at the Vanquish Zero Aker ones as a good replacement. Now will they work with the stock SCX wheels or will they hit the rings?
Here's the link if your interested
Axial ax10 High Steering Knuckles Zero Acker
jdacus is offline   Reply With Quote
Old 02-03-2013, 08:59 PM   #2
Default Re: Vanquish Zero Aker Kuckles
They will rub the tires on the inside so you will need to run spacers on the knuckles so they don't rub as much. Use Traxis plastic wheel spacers. I've run these for a year or so. It's worth the time spent.
im gunna crawl is offline   Reply With Quote
Old 02-03-2013, 09:12 PM   #3
Do you know if they will rub on 1.9 IROKS or not, or is it pretty obvious that they will rub on most tires?
Old 03-30-2013, 01:30 AM   #4
They rub on most all tires, just rubbed a set of iroks and Baja claws pretty bad tonight, need some help on how to not have them rub with axial 8 hole wheels
XJkid93 is offline   Reply With Quote
Vanquish Zero Aker Kuckles - Similar Threads
R2 vs. vanquish Overrev Axial AX-10 Scorpion 26 03-26-2010 05:03 AM
RCP High Clearance Kuckles, why I love 'em! mysharona Axial AX-10 Scorpion 7 07-21-2008 01:45 PM
