02-08-2013, 10:20 PM | #1 |
Newbie Join Date: Feb 2012 Location: stockton
| wheel base
ok i got a dumb question and want to make sure i order the right stuff. looking for a new body and from center of front wheel to center of rear wheel it measures 12 1/4". so i need to order a body that is 12.3" or 313mm correct? like the jeep commanche body, thanks for any input.
02-08-2013, 10:40 PM | #2 |
Rock Crawler Join Date: Nov 2010 Location: south prairie
No such thing has a dumb question. You can pretty much go.with any body you want, all you have to do is either make longer or shorter links. sent from a mobile device dumber than me. |
02-09-2013, 08:32 AM | #3 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
| Re: wheel base
That would be correct the honcho wheelbase is approx. 12.3. That jeep body that you are after is the same wheel base as the honcho. Axial sells the short kit (I think it's 11.6?) it's dingo wheel base or the honcho 12.3 wheel base. If your really going to beat on it I suggest rc4wd heim joints on the lower links all 8. Or vanquish also makes links that are titanium. But you have to piece them together. So you can alter your wheelbase as needed for whatever body you choose. Vanquish sells the links seperately.
02-09-2013, 09:31 AM | #4 |
| Re: wheel base
ok thanks i just want a body that will drop right on what i have now without messing with the links.
wheel base - Similar Threads | ||||
honcho on a small wheel base? and advantage of the long wheel base? | Daddydancool | Axial SCX-10 | 7 | 04-26-2011 06:29 PM |
Wheel base | The Violator | Losi Micro-Rock Crawler | 2 | 11-23-2010 05:16 PM |
wheel base.... | 93'wrangler | Axial AX-10 Scorpion | 5 | 10-18-2008 01:11 AM |
wheel base | collins_12345 | HPI Wheely King | 2 | 08-20-2008 05:44 PM |
wheel base | tapped-out | Traxxas Crawlers | 15 | 04-07-2007 06:48 PM |
