02-15-2013, 04:26 PM | #1 |
Quarry Creeper Join Date: Nov 2012 Location: oshkosh
| Need a link for help
Can someone give me a good link to doing a battery forward conversation on the scx10. Tried looking for one but haven't found any good ones
02-15-2013, 04:45 PM | #2 |
Quarry Creeper Join Date: Nov 2008 Location: NorCal
| Re: Need a link for help
If you don't mind dropping a well-spent $45 bux, consider one of the battery plate's offered by Jevne Racing Last edited by BodiBuilt; 02-15-2013 at 05:03 PM. |
02-15-2013, 04:54 PM | #3 |
It can also be done "on a budget" using nothing but included part's that came with your rig if that's what you're lookin' for... simply swap radio box to the rear, battery plate to the front Last edited by BodiBuilt; 02-15-2013 at 05:02 PM. |
02-15-2013, 08:17 PM | #4 |
| Do u swap the cross members also cuz I notice the front cross member is notched to fit the servo
02-15-2013, 09:05 PM | #5 |
Nvm got it to work
02-15-2013, 10:47 PM | #6 |
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
If you use the supplied spacers to put your battery up front, check your travel with the plate installed that way, and note how much clearance your servo has between it and the bottom of the plate. I'd cut the spacers down as much as you can, especially if your packs are pretty heavy.
02-15-2013, 11:07 PM | #7 | |
| Re: Need a link for help Quote:
But, yes, I would definitely recommend these to anyone who's on the fence with one of these. | |
02-16-2013, 12:22 PM | #8 |
Pebble Pounder Join Date: Oct 2012 Location: Shreveport
ive been on the fence on that battery plate bracket..might jump on it after payday next week.
Need a link for help - Similar Threads | ||||
upper link lengths for SCX10 with stock four link | oscodawave | Axial SCX-10 | 4 | 11-19-2010 08:23 PM |
Link setup on TCS 4 link plates and boulder chassis | sdcrawls | Axial AX-10 Scorpion | 8 | 11-17-2009 02:37 AM |
