Thread: Need a link for help
Old 02-15-2013, 04:26 PM   #1
Default Need a link for help
Can someone give me a good link to doing a battery forward conversation on the scx10. Tried looking for one but haven't found any good ones
bigred22 is offline   Reply With Quote
Old 02-15-2013, 04:45 PM   #2
Default Re: Need a link for help
If you don't mind dropping a well-spent $45 bux, consider one of the battery plate's offered by Jevne Racing
BodiBuilt is offline   Reply With Quote
Old 02-15-2013, 04:54 PM   #3
It can also be done "on a budget" using nothing but included part's that came with your rig if that's what you're lookin' for... simply swap radio box to the rear, battery plate to the front
Old 02-15-2013, 08:17 PM   #4
Do u swap the cross members also cuz I notice the front cross member is notched to fit the servo
Old 02-15-2013, 09:05 PM   #5
Nvm got it to work
Old 02-15-2013, 10:47 PM   #6
If you use the supplied spacers to put your battery up front, check your travel with the plate installed that way, and note how much clearance your servo has between it and the bottom of the plate. I'd cut the spacers down as much as you can, especially if your packs are pretty heavy.
05Fronty4x is offline   Reply With Quote
Old 02-15-2013, 11:07 PM   #7
Proverbial threadkiller
Trubble's Avatar
Won mine in a giveaway.
But, yes, I would definitely recommend these to anyone who's on the fence with one of these.
Trubble is offline   Reply With Quote
Old 02-16-2013, 12:22 PM   #8
ive been on the fence on that battery plate bracket..might jump on it after payday next week.
joshjunior is offline   Reply With Quote
Need a link for help - Similar Threads
upper link lengths for SCX10 with stock four link oscodawave Axial SCX-10 4 11-19-2010 08:23 PM
Link setup on TCS 4 link plates and boulder chassis sdcrawls Axial AX-10 Scorpion 8 11-17-2009 02:37 AM
