02-19-2013, 12:54 PM | #1 |
Newbie Join Date: Dec 2012 Location: Paducah Ky.. / Western KY.
| Needing help ASAP
Ok I'm ordering a slew of parts today. Scx10 honcho. I wanting to lift it to add 2.2s and mudslingers , I'm only wanting to lift via longer shocks , but also going with shock relocation kit on the rear Anyone have a idea of what size shocks ill need for the front and rear? I'm not even sure what size the stock shocks are . I'm sure there is a thread for this somewhere , but I could not find it in any search.. Thanks alot. |
02-19-2013, 01:01 PM | #2 |
Rock Stacker Join Date: Jun 2012 Location: Backwoods,Arkansas
| Re: Needing help ASAP
I used 110mm rc4wd shocks on my scx, cleared my mudslingers just fine when i ran them last year |
02-19-2013, 01:40 PM | #3 |
| Re: Needing help ASAP |
02-19-2013, 01:54 PM | #4 |
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
Stock are considered to be ~90mm from eye to eye so 110mm shocks should give you a good bit of lift if you are running a fully sprung setup. Mind your drive shaft angles and make sure they aren't binding at your desired height. You can increase your upper link length to maintain a good angle with more lift. To check if longer shocks will cause binding before you order you can unhook the top shock mounts and lower them about 3/4"-1" letting the axle drop and make sure your tires still spin freely. Pull the pinion off the motor when you do this. The rear shocks will need to be a bit shorter than whatever you end up with in the front. Maybe a set of 110mm in the standard verticle layout up front and the stock shocks in the rear would work out. |
02-19-2013, 01:59 PM | #5 |
Quarry Creeper Join Date: Jan 2013 Location: Vancouver, B.C.
I run 2.2 with slingers on SCX-10 using proline 95mm shocks and a Vanquish shock mount raiser for the axel. You get extra offset on the wheels also running hex hubs for the AX-10, depending on your wheels choice and offfset, that come into play also.
02-19-2013, 03:38 PM | #6 |
the mud slingers aren't very tall , you really wont have to lift it at all.
02-19-2013, 03:40 PM | #7 |
I order 2.2 mayhem engineering wheels with .650 off set , I think I'll try the 95 mm and wait on the shock relocation kit and go with a vp riser for now.. Thanks alot
02-19-2013, 06:26 PM | #8 |
you might only need the VP riser on the front (15$ for a set), I know I could run in the rear witout it and I even tucked my bumpers way in (redrill further holes) and it still does not interfere in the rear.
Needing help ASAP - Similar Threads | ||||
Needing to be educated?!! | schmaged88 | Newbie General | 3 | 11-08-2012 04:48 PM |
Needing help | TRIGGER | Redcat Crawlers | 5 | 01-10-2011 10:01 PM |
