03-24-2013, 11:59 AM | #1 |
Newbie Join Date: Feb 2013 Location: abilene
| scx10 Problems
Okay I have been having a problem for a few days now with this thing. It was workign great and then I broke a chub so I ordered new 8* VP chubs, steering knuckles, HR wheel spacers and wraith 2.2 wheels and tires. It is ttwitching and acting like the transmitter batteries are dead so I went and bought new ones last night and that wasnt the problem. It seems like I can ease into the throttle but if I give it full throttle it wont move. Here is a video of what it is doing. Scx10 problem - YouTube Last edited by djbeck88; 03-24-2013 at 12:01 PM. Reason: more |
03-24-2013, 12:02 PM | #2 |
Rock Crawler Join Date: Jul 2012 Location: Grand rapids
| Re: scx10 Problems
Is it all stock electronics? Could be connection issues
03-24-2013, 12:03 PM | #3 |
Quarry Creeper Join Date: Jul 2010 Location: Canada
| Re: scx10 Problems
looks like dirty brushes, or a bad sensor wire if its a brushless. Did you run the truck in snow or water? edit: watching it again I see its a stock motor, difficult to clean only the brush contacts, but if its not a connection somewhere else causing the problem you can remove the motor from the transmission and run it for a few minutes in a glass of clean water, should clean up the contacts. Last edited by Weapon; 03-24-2013 at 12:06 PM. |
03-24-2013, 12:03 PM | #4 |
| Re: scx10 Problems
I forgot to add that. The RX is stock the ESC is stock and I switch between a 20t 27t and 55t Axial motors
03-24-2013, 12:07 PM | #5 |
Quarry Creeper Join Date: Mar 2013 Location: Moscow Russia
| Re: scx10 Problems |
03-24-2013, 12:08 PM | #6 |
| Re: scx10 Problems
so it does this with all three motors?
03-24-2013, 12:11 PM | #7 | |
| Re: scx10 Problems Quote:
03-24-2013, 12:12 PM | #8 | |
| Re: scx10 Problems Quote: yes all three of them. | |
03-24-2013, 12:13 PM | #9 |
| Re: scx10 Problems
my next step would be trying another esc, after eliminating connection issues to the motor which you seem to have done.
03-24-2013, 12:15 PM | #10 |
| Re: scx10 Problems I would. But nobody around here plays with em too much and I dont have a LHS. So I would have to order one. lol Abilene Tx needs a hobby store in a bad way
03-24-2013, 12:21 PM | #11 |
| Re: scx10 Problems
definitely do all the free stuff first. check the water proof on your receiver, alcohol wash it to be sure (a wet radio might act like that). also its reaching but check the water proof on your servo as well. If you didn't water proof your stuff you will want to alcohol bath it and scrub with an old toothbrush to get rid of any crap left behind on the circuit boards.
03-24-2013, 12:22 PM | #12 | |
03-24-2013, 12:24 PM | #13 |
| Re: scx10 Problems
I mean take some isopropyl pour it in a dish or bowl and put the piece in to soak. after taking it out of the plastic housing. even if it was waterproofed you should maybe check it anyway. I use balloons to do my radio now I double bag em because they sometimes leak, I also put in a desicant pack with the radio in case it does leak a little. Last edited by Weapon; 03-24-2013 at 12:26 PM. |
03-24-2013, 12:33 PM | #14 |
| Re: scx10 Problems
If none of that stuff works, short of replacing parts to test. I got nothin.
03-24-2013, 12:33 PM | #15 | |
03-24-2013, 12:41 PM | #16 |
| Re: scx10 Problems
that's how corrosion works though everything works fine come back a week later and bad connections everywhere. it happens to my brushed motors if I forget to clean the brush contact after a wet run. if you have any desicant packs (those little white salt pack things that come with electronics) throw one in the balloon with the radio. they work really well. esc shouldn't be ballooned though as they need to cool it should be taken apart and the board plastidipped with just the cooling fins left exposed. good luck man hope you get it sorted. I'm off to go wreck one of mine in the snow and water now |
03-24-2013, 04:18 PM | #17 |
Quarry Creeper Join Date: May 2010 Location: scotland
| Re: scx10 Problems
mine was doing something like that last week it would go forward a wee bit then just stop for no reason and sometimes it would just go into reverse after going forward a few feet. it turned out to be the receiver was faulty put a new one in and now it works like it should
03-24-2013, 04:36 PM | #18 | |
03-24-2013, 04:38 PM | #19 |
Rock Crawler Join Date: Oct 2012 Location: Casper
| Re: scx10 Problems
Do you have a bec on your servo? I'm betting the servo is causing the problem.
03-24-2013, 05:32 PM | #20 |
Newbie Join Date: Mar 2013 Location: Dallas
| Re: scx10 Problems
Long shot but try a different battery. When a battery fails it actually can spike in voltage. The stock esc does not like anything more than 6 Nimh/2s lipo. I had the exact same symptoms, my 2s was apparently shorting causing my esc to over volt. Did not like full throttle at all, would sometimes respond to low throttle then shut down. |
scx10 Problems - Similar Threads | ||||
scx10 problems | Bronco2x84 | Axial SCX-10 | 3 | 01-10-2013 05:22 PM |
scx10 ax2 problems | yzkeb125 | Axial SCX-10 | 4 | 12-16-2012 10:00 PM |
SCX10 kit problems | AG74683 | Newbie General | 28 | 09-06-2011 07:28 AM |
scx10 problems???? | dunwoody | Axial SCX-10 | 1 | 05-18-2011 05:44 PM |
Axial Scx10 problems... | Veilside159 | Axial SCX-10 | 30 | 12-09-2009 02:12 PM |
