2dr jk rubicon on dingo frame Hello, I have a 2 Dr jk body from pro line and I am trying to mount it to my dingo frame. The front is going to work OK but the rear extended body post is too short even after drilling new mounts in the bottom of it to get the body up higher. The way it is now is I have my axial rock sliders on and the body sits on the sliders and the rear body post still doesn't touch. Anyone have a suggestion on how to mount this body? I don't want to use Velcro or magnets to hold it down, just body clips. |
Re: 2dr jk rubicon on dingo frame I'm sure you can find longer posts try these...you might have to modify a bit...but that's part of this hobby..."thumbsup" Parma 4" Body Post Nylon |
Re: 2dr jk rubicon on dingo frame At first I trimmed the rocker panel so it would sit right on the sliders. The rear post has an extra hole drilled at the bottom and is mounted all the way up. http://i639.photobucket.com/albums/u...ps313522ed.jpg Then I wanted it even lower so I took the sliders off of mine and slammed the body way down. I also removed the plastic frame off the battery mount so the front would clear and trimmed the bottom of the grille around the chassis frame rails. Here the rear post is mounted two holes down. I think it looks more scale when it is lower. http://i639.photobucket.com/albums/u...ps7d617324.jpg |
