02-27-2013, 02:54 PM | #1 |
Rock Crawler Join Date: Feb 2013 Location: Casper
| ?? for the ones useing the Cherokee xj body
Im getting ready to order the 4 link set up aluminum link and was wondering what size to get (is there even a lenght to order?). I want the high clearance link. Would 4 link be the way to go or 3 link? Ive got the jeep Cherokee xj on the trail Honcho frame. TIA J. |
02-27-2013, 03:14 PM | #2 |
Pebble Pounder Join Date: Sep 2012 Location: Rockford
I'm kind of a noobie but I'm pretty sure you need the 91mm links that's measured without the ends. I have the axial aluminum upgrade kit which are 91mm and I have the cherokee body. Sent from my iPhone using Tapatalk |
02-28-2013, 02:25 AM | #3 |
Pebble Pounder Join Date: Aug 2012 Location: Lewisville, NC
| Re: ?? for the ones useing the Cherokee xj body
^ Ditto, 91mm straight links. The bent lower links will only cause clearance issues for you, because they will contact the uppers when the axles flex. I tried it once before, no go... They looked really out of place on a scaler too, but thats just my opinion.
02-28-2013, 08:18 AM | #4 |
Thanks all. Sent from my table |
06-05-2013, 12:45 PM | #5 |
Quarry Creeper Join Date: Jul 2009 Location: Dublin,Ireland-Cluj,Romania
same problem here also.so lower liks would be 91 mm,but what about the upper links?how long should they be?
06-05-2013, 04:11 PM | #6 |
Quarry Creeper Join Date: Aug 2010 Location: Brisbane Australia
For the Cherokee you're better getting the alu upgrade kit for wheelbase 11.3" (290mm). Gives you all the links upper and lower (upper links on the 4 link need the 20mm added to lengthen it).
06-06-2013, 11:45 AM | #7 |
ok,thx for the info,but whats the lenght of the upper link?
06-06-2013, 01:31 PM | #8 |
here is what i got in the body description: This is the Pro-Line Jeep® Cherokee Clear Body for the Axial SCX10 Honcho Long wheelbase, (313mm 12.3") |
