02-27-2013, 08:49 PM | #1 |
Rock Stacker Join Date: Feb 2013 Location: NY
| Scx10 Rubi stock shocks. Ride height adjustable?
After loading up my rig with lots of gear for a long wheeling weekend my rig is busting a sag. I can't raise it back with the stock shocks can I? Question number 2. If I switch from the stock 27T motor to something like a 35T how much different will it be? Worth the change? |
02-27-2013, 09:30 PM | #2 |
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
| Re: Scx10 Rubi stock shocks. Ride height adjustable?
That's what the threaded shock bodies are for. Tighten the ring down some to increase preload. Motor choice depends on driving style and terrain. If you are strictly a slow crawler a higher turn motor is better. 35T is somewhat of a do-all motor with decent wheel speed and good low end power. Most of the difference you would notice would be if you went with a high quality purpose built hand wound crawler motor. |
02-27-2013, 10:15 PM | #3 | |
| Re: Scx10 Rubi stock shocks. Ride height adjustable? Quote:
02-27-2013, 11:15 PM | #4 | |
Rock Stacker Join Date: Sep 2011 Location: mcminnville
Unless you're in love with the wheel speed from that 27t motor a 35t would be an excellent choice. Probably the most popular. If you don't mind sacrificing a little wheel speed, get the 35t you'll love it. | |
02-27-2013, 11:37 PM | #5 | |
Or will I actually be able to crawl even slower? | |
02-27-2013, 11:43 PM | #6 |
If you want to crawl slower you can reduce your pinion size and/or use a less aggressive throttle profile/negative exponential (if your ESC/transmitter have the settings). Higher turn motors naturally have more power at lower RPM's so they do lend themselves to more low speed smoothness if that's what you're after. Again, if your style is to slowly crawl around then a higher turn motor is better. You get lower motor temperatures, less wear and tear, more low end and longer run times. I run a 55T on 3s which in terms of RPM is the equivalent of a 35T on 2s. It's perfect for my needs which is 99% slow controlled crawling. If you are spending a lot of time giving your 27T more than half throttle then you may miss it a little if you go with a higher turn motor. Last edited by 05Fronty4x; 02-27-2013 at 11:51 PM. |
02-28-2013, 06:21 AM | #7 |
Rock Crawler Join Date: Jan 2010 Location: In the lair editing video
You wont see a huge difference. I run a 27 turn in my scaler. It crawls along just fine, and has a little pep when you want it.
02-28-2013, 11:31 PM | #8 |
| Re: Scx10 Rubi stock shocks. Ride height adjustable? |
Scx10 Rubi stock shocks. Ride height adjustable? - Similar Threads | ||||
Adjustable height system | ABnormal | Axial AX-10 Scorpion | 21 | 04-29-2009 03:29 PM |
Ride height versus max height | Manson | Axial AX-10 Scorpion | 9 | 10-03-2008 01:26 PM |
Adjustable chassis height design... | Stallion1967 | Tamiya TLT Crawlers | 22 | 08-03-2007 06:52 PM |
Adjustable Height RC Crawler | john alardin | Chit Chat | 16 | 06-29-2007 09:06 AM |
??? that might light a fuse but...shocks /ride height | Gabe | Tamiya TLT Crawlers | 14 | 06-08-2007 11:12 PM |
