Thread: Rolling resistance
Old 03-01-2013, 12:49 PM   #1
Default Rolling resistance
Before I start looking for a problem and take my Honcho apart I thought I would ask the question. How easily should the truck move with no power applied. I have disconnected both drive shafts and the wheels move with very little resistance. With drive shafts connected the wheels will skid when pulling it. Anyone else experience this problem if it is a problem. Under the same conditions my Wraith moves very easily. Should I start looking for motor resistance or transmission drag? The truck is new (RTR) with less than one pack through it.
Moe
moejean is offline   Reply With Quote
Old 03-01-2013, 01:05 PM   #2
Default Re: Rolling resistance
If you are brushless and 4pole then I think the resistance is normal.
I know my stock Wraith and stock SC10 would roll fairly easily. When i upgraded to brushless 4pole on the SC10 it didn't budge until under power. Scared me at first thinking the motor was locked, but I contacted the MFG and they explained that this was normal. Same with the 4pole motor on the wraith.
Not sure about brushed systems.
offroadace is offline   Reply With Quote
Old 03-01-2013, 02:37 PM   #3
best way to tell is to remove the motor then push it. it should roll easy, with the motor connected you will get resistance.
crawlhog is offline   Reply With Quote
Rolling resistance - Similar Threads
wraith rolling resistance sintasticjoe Axial Wraith 0 02-03-2013 01:37 PM
Alot of resistance slash 127 Newbie General 8 07-07-2012 11:47 PM
Gear case resistance? gtxr Axial XR10 8 04-29-2012 10:12 PM
truck won't go with ANY resistance, fine without mdchris Electronics 4 10-23-2011 08:31 PM
D.U.D. - noticable resistance? HndsWthtShdws Tamiya Clod Buster 4 12-07-2007 01:18 PM
