03-06-2013, 01:13 PM | #1 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| grinding axles for more steering throw
found this picture somewhere from this site.. did this with a 4 1/2in angle grinder.. used a file to make it all even. used a dremel to give the inside of the axles more angle.. got a lot more steering.. however i did this to 3 axles now. all 3 broke.. not even close to a full pack.. my truck has a 35 turn motor 2.2 tsls rest is stock.. any ideas?? thanks |
03-06-2013, 04:12 PM | #2 |
Pebble Pounder Join Date: Jul 2010 Location: malta
| Re: grinding axles for more steering throw
These are more promising Axial Universal Joint Set (2) |
03-06-2013, 04:57 PM | #3 |
You can only gain a little that way or the cup binds at full throw and causes the breakage. The Axial CVD's listed above are slightly stronger than toothpicks. The XR mod, Vanquish VVD's or Super 300's are the options to gain steering and strength. |
03-06-2013, 07:10 PM | #4 |
axial cvds are crap.. seemed to do pretty good. i had a good bit more steering.. wish i know knew why they were busting
03-07-2013, 03:48 AM | #5 |
Rock Stacker Join Date: May 2012 Location: Kelso
I did this mod to my scx10 axles i run a tekin pro4 4000kv motor with tall 1.9s and have only broke one axle do to hoping rocks
03-07-2013, 02:19 PM | #6 |
maybe its was the heat?
03-07-2013, 03:57 PM | #7 |
You see in the photo how the pin is almost popped out of the cup? If you grind to far (which 99% sure you have) that pin pops out when you turn. At that point one of two things has to happen. Either A: the C rips loose and pops off or B: the dogbone breaks. You can try to turn down your EPA's to keep the pin from popping out, chances are turned under a bind it'll still pop out. |
03-10-2013, 08:51 AM | #8 |
ok maybe i just grinding to much.. going to try this one more time. not to much grinding this time. see how it goes..
grinding axles for more steering throw - Similar Threads | ||||
xr steering, but no throw? | 0260b4u007 | Axial AX-10 Scorpion | 32 | 02-26-2013 12:19 PM |
Need Help with steering throw! | 99xjlove | Losi Mini-Rock Crawler | 15 | 09-28-2012 11:02 PM |
steering throw | bahogtubig | Redcat Crawlers | 9 | 07-13-2011 02:38 AM |
Steering throw????? | WKcrawler17 | HPI Wheely King | 13 | 06-30-2009 01:24 AM |
Steering throw | hitman46mod | HPI Wheely King | 6 | 11-22-2007 01:21 PM |
