03-11-2013, 11:01 PM | #1 |
Newbie Join Date: Dec 2012 Location: Canada
| G Made XD piggybacks installed!
Just got finished installing some G Made XD Piggybacks on my 2012 Wrangler SCX 10. I went with the 103 mm. I noticed that other than the basic leaking and lacking quality of the stock units, I wasn't utilizing all the up travel they had to offer so why not go longer? I wasn't disappointed! There's no driveline bind and I'm getting way better droop, dampening and a bit of ground clearance. I changed out the springs for something softer as the ones they came with were a bit stiff. Too late to go and test outside. |
03-11-2013, 11:21 PM | #2 |
Rock Crawler Join Date: Oct 2012 Location: Casper
| Re: G Made XD piggybacks installed!
Do I see scale bump-stops in those piggy-backs? Looks good!
03-11-2013, 11:33 PM | #3 |
No. There is an integrated bump stop on the shock shaft. What you're seeing is the FUNCTIONAL reservoir with rebound adjustment. Absolutely awesome shocks so far.
03-11-2013, 11:49 PM | #4 |
Newbie Join Date: Feb 2013 Location: Omaha
Nice I'm looking at them for mine wasn't sure of length just helped me out thanks bro. Here's mine. |
03-11-2013, 11:50 PM | #5 |
Also what tires u running
03-12-2013, 12:02 AM | #6 |
TSL super swampers. Glad I could help cause I'm kind of a newb.
03-12-2013, 12:34 AM | #7 |
Quarry Creeper Join Date: Apr 2008 Location: PNW
Do you have any non flex shots to show the ride height?
03-12-2013, 07:34 AM | #8 |
I'll grab some tonight after work.
03-12-2013, 08:12 AM | #9 |
Pebble Pounder Join Date: Mar 2013 Location: Honolulu
Let us know how it crawls please. I'm wondering if its going to be more prone to rolling?
03-12-2013, 03:01 PM | #10 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
try pressing the 'ENTER' button after you put the pics in... Looks awesome! |
03-12-2013, 03:21 PM | #11 |
03-12-2013, 07:01 PM | #12 |
Quarry Creeper Join Date: Nov 2012 Location: oshkosh
Looks awesome I'm going to gets the same shocks for the same truck glad to c a pic of what it'll look like what weight oil did u use and what's the spring rate?
03-12-2013, 08:48 PM | #13 |
03-12-2013, 08:53 PM | #14 |
| I used the oil they came with and opted for a soft front and firm rear set up with the pistons. The springs were swapped out for Losi 2.75" 1.6 Rate units as they were softer.
03-12-2013, 10:50 PM | #15 |
03-12-2013, 11:31 PM | #16 |
| Nah. Just around the living room cause its pissing out. I have an intermittent chatter from the drive line now if I turn it upside down and hold the throttle at medium speed. My guess is that this may be the driveshafts binding a little. It doesn't happen when actually driving around any thoughts? |
03-12-2013, 11:56 PM | #17 |
Ok I just tried the search and found that the DS needs to be lined up. I pulled my shafts apart so I'm sure that's my problem. Fixin it tomorrow.
03-13-2013, 10:14 AM | #18 |
Quarry Creeper Join Date: Mar 2013 Location: Plymouth
looks good! How were they bleeding with those piggy backs?
03-13-2013, 11:06 AM | #19 |
03-13-2013, 01:44 PM | #20 |
RCC Addict Join Date: Feb 2011 Location: York
Stock scx10 shocks, when built (or rebuilt) right are phenomenal. The gmades sure are cool though! |
G Made XD piggybacks installed! - Similar Threads | ||||
Piggybacks | stick-boy-rick | G-Made Crawlers | 7 | 03-23-2013 03:56 PM |
Gmade piggybacks for TF2 | NielsVV | RC4WD Trail Finder 2 | 1 | 10-13-2012 09:20 PM |
