03-12-2013, 05:45 PM | #1 |
Newbie Join Date: Jan 2013 Location: The Desert
| heads up on the Dinky honcho interior.
Just fyi, there isn't room to run a standard battery pack in the truck with this kit installed and still have the battery and body where axial put them. Maybe a shorty pack or some kind of aircraft pack might fit. I thought that the battery might go down the trans tunnel but you would have to raise the body up at least 3/4 on an inch. The fire wall comes down right at the front of the rear battery strap. Oh, and I think mine is hitting the spur gear cover a little bit due to my trans being flipped around in order to run a dig setup, I think a little heat to put a bump in the floor of the interior or raise the body mounts one hole would cure this.
03-12-2013, 06:56 PM | #2 |
Newbie Join Date: Oct 2012 Location: Flint
| Re: heads up on the Dinky honcho interior.
I just cut the tunnel to fit the battery, cant really see it from the outside.
03-12-2013, 08:35 PM | #3 |
I was thinking about that but the batteries I use would come out to halfway between the dash and the front of the seat. It's not a big issue for me, I'm just going to get some shorter batteries and make them dedicated honcho packs. I just thought I'd throw that out there in case someone was doing research before they buy. The kit is well made and looks awesome in the truck, I'd buy it again in a heart beat.
heads up on the Dinky honcho interior. - Similar Threads | ||||
Dinky Honco interior in a Tundra body? | Big Daddy | Paint and Body | 13 | 10-28-2014 03:07 AM |
Dinky R/C's "Honcho" Interior Kit Giveaway!!! | muddauber7 | General Crawlers | 114 | 08-02-2012 02:48 PM |
