12-28-2013, 10:29 PM | #61 |
Newbie Join Date: Dec 2013 Location: Hollywood
| Re: SCX10 Honcho mods
Are you interested in selling the 7 spoke wheels?
01-09-2014, 01:30 PM | #62 | |
Newbie Join Date: Oct 2013 Location: Terrace
what kind of axles are those? im looking for a set so i can start my build. Quote:
01-09-2014, 07:57 PM | #63 |
Quarry Creeper Join Date: Apr 2013 Location: Upstate
More pics of that Silverado body please!
01-10-2014, 05:32 AM | #64 |
| Re: SCX10 Honcho mods |
04-28-2014, 01:57 PM | #65 |
Quarry Creeper Join Date: Mar 2013 Location: Moscow Russia
Time to update my scale business. It's been a while since I took my SCX10 out. Last few months I was all about moving to Moscow, taking new job and no time for hobby. Last weekend I went to park to meet other scale fans. I am impressed with local scene, did not expect to see so many people with RC 4x4 rigs Some low resolution pics >>what kind of axles are those? im looking for a set so i can start my build answer above, standard Axial SCX10 axles >>More pics of that Silverado body please! Coming soon. It is Pro-Line 2007 Chevy Silverado body (3230-00) with Dingo fender flares (AX80040). Body wheel base is 13", will require some links stretching. Last edited by nersik; 04-28-2014 at 02:08 PM. |
04-30-2014, 12:30 AM | #66 |
Steering is occupying my mind lately. High clearance knuckles and universal joints can offer more angle then stock. Still Ackerman angle is completely opposite to what it should be. Found a link for German solution, here is pic to get the idea With Axial knuckles as they are the only option is to move steering behind the axle. That requires modified steering link like above or like this one Will need to think of something |
05-04-2014, 01:44 PM | #67 |
Some more pics from todays fun run in Izmaylovo Replacing servo. Stuck while driving straight on even surface and will not move. After reassembling it at home works fine. Don't know what happened to it. And 2 short videos |
01-11-2015, 01:57 AM | #68 |
Joined winter rc season last weekend. Performance of my rig in snow is below average. Wheels are getting rock solid in no time. First I thought it is because of ice forming on warm tires. So I cooled my rig outside before putting it on snow. But wheels were still solid. Turned out Panther RC foams are freezing. I decided to try to make foamless wheels. Took the foams out and assembled wheels outside at -4C (25F). I put small amount of grease on tire bid so it will fit easier and make a tighter seal. Indoor at around 22C (72F) tires acquired a bit more pressure. They hold 2.8 kg (6.2 lbs) rig quite good. Looks like running with low pressure. Will wait for colder weather to get more pressure in wheels. Another way is to open ventilation hole in the rim and put wheels in freezer. I did not do it yet because my wheels are sealed form outside and inside. Last edited by nersik; 01-12-2015 at 12:23 AM. |
01-20-2015, 01:29 PM | #69 |
Second BMS 28A servo died. It works fine until you put it in water and mud. 1st thing to go out is potentiometer. And all electronics is very sensitive. Servo that died half a year ago suddenly came back to life. At least potentiometer seems to work OK. But it turns left not so good as it turns right, amplitude and speed. I was going to replace potentiometer. Had a winch servo I wanted to use as a donor. But Its potentiometer is different and not transferable to steering servo. There is are reduction gears so the output shaft can make several turns while electrode make only 1/4. This is how pot looks inside |
01-20-2015, 02:08 PM | #70 | |
| Re: SCX10 Honcho mods Quote:
Either way, you've now got yourself a strong servo winch | |
02-10-2015, 01:05 PM | #71 |
I added some conformal coating to the board, sealed the case with silicon and put o-ring on servo arm. For now servo survived 3 hours run in snow, water and mud. Going to mount servo on chassis for more reliability. Will I get a lot of steering trouble if I keep 4-link front with CMS? Also tried to wash Panther RC foam. I heard memory foam lose its properties after washing machine. No, it does not. Still turns into wood in the cold. Before freezing After |
01-18-2016, 05:16 AM | #72 |
After almost a year I am back. Truck has been sitting on the shelf all this time. Missed summer season. I thought XR4 radio was dead. But during New Year holidays I installed new servo (on chassis this time) and found radio working fine after several resets. Couple pics from park run |
01-19-2016, 02:38 PM | #73 |
It is snowing every day. Or at least every other day. I decided to improve tire performance with chain. Bought 8 meters (26 ft) of 1mm - smallest size available in hardware store. Guys told me I will need at least 7 meters. That is not true. 1 meter (~3'4") is enough for 1.9 Irok. Here is the result |
01-20-2016, 06:59 AM | #74 |
Quarry Creeper Join Date: Nov 2015 Location: US
| Re: SCX10 Honcho mods (Chevy Silverado)
Looks like they are falling into the tread a bit. Would you have used larger chain? Sent from my SM-N910T |
01-20-2016, 11:20 AM | #75 |
They are. Tread pattern is very deep on sides. Chain links go well over tread in the middle. Next available size was too big for 1.9 wheels. Maybe ok for 2.2 and monsters. Anyway chains add some look) Not sure even big chain will really work in deep snow like we are having now. On the picture above you can notice bigger chains on Summit. And it still getting stuck pretty fast in untouched snow. BTW my chains weight 23 grams (0.8 oz.) each. Just for info. |
02-01-2016, 02:08 PM | #76 |
Getting ready for summer season. Got Vaterra TSL tires. They do not fit standard wheels because of different bead. Here is Vaterra TSL (left) compared to RC4WD Irok (right) There was no way to mount Vaterra tires. No matter how hard I tried the only way is to use different rings. New ring (left) next to original (right) And it is finally assembled Size of new ring in mm |
02-07-2016, 08:46 AM | #77 |
My SCX10 came with cut Honcho bumper. I don't see how it increase performance. Found used full width bumper, I think it looks better. Cut bumper and full bumper This weekend I took wheel chains for first run. Since last time it's been warm, above freezing. Then temperature went down again. So no deep snow, only hard snowpack. Don't know about deep snow but chains do work in slippery conditions. They really help to get up icy hills. Some more pics from trail. Also had a nice 1:1 run the day before Last edited by nersik; 04-19-2016 at 01:34 PM. |
04-19-2016, 02:22 PM | #78 |
Spring. River. Lots of mud. TSLs work good. Lost of mud Some hill climbing And more dirt |
04-24-2016, 01:38 PM | #79 |
Vaterra TSLs are foamless now. Assembled wheels in freezer. Method works good. Tires are soft and look scale. Lots of pictures from Sunday run |
04-24-2016, 01:39 PM | #80 |
Part 2 |
SCX10 Honcho mods - Similar Threads | ||||
2 Honcho mods for me tonight | Big Daddy | Axial SCX-10 | 1 | 08-23-2011 10:07 PM |
First Mods to the Honcho... | cptcorn | Axial SCX-10 | 29 | 09-26-2010 05:45 PM |
first mods to your scx10? | buddha.licious | Newbie General | 8 | 10-28-2009 08:36 AM |
SCX10 Mods help | hibbs | Axial SCX-10 | 0 | 03-18-2009 09:07 AM |
