03-16-2013, 01:47 AM | #1 |
Rock Stacker Join Date: Jan 2012 Location: Walters, OK
| Wild boar driveshaft problem, need help
Hey guys, I am having trouble installing my driveshafts, my problem is that I cannot get the screw to go through. What should I do?
03-16-2013, 05:36 AM | #2 |
Pebble Pounder Join Date: Jan 2012 Location: McPherson
| Re: Wild boar driveshaft problem, need help
Which screw are you referring to? If you are referring to the screw that holds the drive shaft to the axle, make sure you have the input shaft of the axle pulled all the way out or the hole won't line up properly. The one connecting to the output shaft of the transmission shouldn't be an issue. |
03-16-2013, 10:16 AM | #3 |
Yep that's it, but I just used set screws, thanks.
Wild boar driveshaft problem, need help - Similar Threads | ||||
MIP driveshaft problem | nonstopboost | Losi Mini-Rock Crawler | 17 | 07-26-2010 09:43 PM |
driveshaft problem solved | crawler-kid | Venom Creeper | 4 | 12-15-2009 04:18 PM |
driveshaft problem | iwantoffroad | Tamiya TLT Crawlers | 14 | 07-20-2006 10:11 AM |
