03-23-2013, 09:48 AM | #1 |
Newbie Join Date: Dec 2012 Location: marysville
| which thread locker to use?
I have some red thread locker but it seems to get my stuff to tight and I strip it. Tired of drilling those things out
03-23-2013, 09:57 AM | #2 |
Quarry Creeper Join Date: May 2010 Location: scotland
| Re: which thread locker to use?
you want to try blue thread lock it should make unscrerwing things easier as its not permanent like the red stuff
03-23-2013, 11:01 AM | #3 |
Newbie Join Date: Feb 2012 Location: Colorado and won't Leave...
You also do not need to SOAK the screw. Light application works best. Never use Red unless you absolutely will not want to remove it. (Besides drilling it out).
03-23-2013, 02:19 PM | #4 |
Rock Crawler Join Date: Jul 2011 Location: palm desert (southern cali)
i use red ALWAYS blue sucks get some good allen wrenches and youll be fine its not permanent and sometimes you can add heat it helps loosen it up and yes i SOAK em in RED lock TITE
03-23-2013, 03:38 PM | #5 |
Yeah.. the OP said he used Red and was wondering what other people were using... So we said " Blue "... Use Red all you want.. Everyone has an opinion.. but it seems your method may not be working that well for you.. since you said... JDMGUY70 Wrote: "man i need these for my stripped hub and chub screws but i have no way of drilling and taping a hole" (In another post) We are all here to help each other out. The OP just wanted some advice. Using lots of any Thread Locker is a bad idea. That is from over a decade running Nitro... and screws just seem to FALL out of those machines if you dont use a bit of Blue thread locker. Never had an issue with Blue and depending on where the screw was, a small amount of Silicone sealant over them if they were getting a bit stripped / loose. The silicone is easily peeled off, then the screw can be removed. |
03-23-2013, 03:54 PM | #6 |
Newbie Join Date: Jan 2013 Location: newfoundland canada
Agree with the general concensus of using blue threadlock . A little dab on the end of on side of the screw is all that is needed . This advice from 25 years as automotive tech .
03-26-2013, 12:53 AM | #7 |
Pebble Pounder Join Date: Jan 2013 Location: Reno
another good one is nail polish, yea its a tad lady-ish, but it works really good and the ol ladys never finish a bottle so you can always have plenty... seriously it works good
03-26-2013, 03:29 AM | #8 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
I use blue Locktite quickstik 248. A lot cleaner and easier than using liquid threadlock.
which thread locker to use? - Similar Threads | ||||
Ring gear screws won't FFFFFFFFFFFFF thread into the locker! | SStone | Axial SCX-10 | 7 | 12-25-2009 08:39 PM |
how to remove thread locker? | Mr. Ed | Newbie General | 13 | 02-24-2009 11:53 PM |
Red Thread Locker 271 | whipnet | Axial AX-10 Scorpion | 8 | 05-21-2008 07:22 PM |
Thread locker?? | rockwell | Newbie General | 10 | 06-14-2006 12:18 PM |
