03-23-2013, 07:43 PM | #1 |
Quarry Creeper Join Date: Dec 2006 Location: Dirty Jerzee
| Chassis mounted steering question
I have searched high and low within the forum but have come up empty.... Seems that the Hand Brothers and RC4WD chassis mounted steering options are just about impossible to find. I bought and sold one a few months ago (didn't even have a SCX10 at the time - Now I am kicking myself).... I can't believe the manufacturers would kill off a "must do" scale mod like this. My question is - What are the alternatives to moving the steering servo to the chassis? |
03-23-2013, 08:31 PM | #2 |
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
| Re: Chassis mounted steering question
I hear you, I kept a wanted ad bumped for a week or more for a Hand Brothers CMS kit without a single nibble. I even posted in Vanquish's "New Idea" thread about making a CMS kit. There is a huge gap in the market for a quality kit, and I know they are more than capable in delivering, even if it's overpriced like most or all of their stuff. DIY it! Check out this guy's homemade bracket. My JK kit assembly. |
03-23-2013, 08:37 PM | #3 |
Quarry Creeper Join Date: Apr 2008 Location: PNW
Rumor has it a VP kit is in the works.
03-23-2013, 08:53 PM | #4 |
Search some of the old Honcho builds, the stock Axial servo mount ( the one that bolts to the axle housing) works perfectly for mounting the servo on the frame rail.
03-23-2013, 09:26 PM | #5 |
Newbie Join Date: Apr 2012 Location: Somewhere in Vancouver
I got one similar to this one: GCM Racing WebStore-2013 - SCX Servo Mount I had a custom one designed to fit my needs but well worth it. Looks scale performs great. You'll more then likely need a panhard kit once you install a cms. It's the only con to changing the stock location. Anyways look around theres some good info on mounting your servo on the chassis. |
03-23-2013, 09:38 PM | #6 |
Quarry Creeper Join Date: Dec 2009 Location: At your moms,she says hi!
| Re: Chassis mounted steering question |
03-23-2013, 10:09 PM | #7 | |
A stronger servo helps. Seemed to have lost a little torque to wheels | |
03-24-2013, 08:04 PM | #8 |
Rock Stacker Join Date: Jan 2013 Location: Boise, ID
Is this mod basically just for scale looks, or are there any steering benefits?
03-24-2013, 08:12 PM | #9 |
03-24-2013, 08:14 PM | #10 |
Quarry Creeper Join Date: Oct 2008 Location: Reno, NV
A CMS is really only for scale looks. With the stock servo mount on the chassis and a bit of time to make a panhard, I'm sure you could whip a CMS of your own up.
03-24-2013, 08:14 PM | #11 |
We are testing the VP unit now, look for it in the coming weeks. Very nice piece for sure.
03-25-2013, 07:19 AM | #12 |
03-25-2013, 07:32 AM | #13 |
Quarry Creeper Join Date: Sep 2008 Location: Fab Shop
Great news! Looking forward to the release.
03-25-2013, 11:01 AM | #14 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
| Re: Chassis mounted steering question not really gaining steering benefits other than more scale/realistic setup - but as far as front articulation goes, the CMS kit will usually help keep a SOA from hitting stuff between the frame rails when you compress the front with lots of articulation/no bump stops. good to hear VP is going to be making a kit.
03-26-2013, 07:41 AM | #15 |
Quarry Creeper Join Date: Apr 2011 Location: Canada
oddly enough I just made a mount for my servo in the chassis, id say for 20.00 just order the level 3 one though. It wasn't hard to make but now I need to figure out a pan hard for it I think. All I did was take standard piece from a dingo kit and cut it to fit then mounted the servo tray to it. I think its just the piece at the back that's sits between the frame rails and makes it flat. I cut off all the extra pieces and made it slide in the frame rails to where I wanted it. |
03-26-2013, 08:01 AM | #16 |
Cquit.. Are you 4 linked? I haven't had any issue out of mine, after I 4 linked it. Great work too.. |
03-26-2013, 08:35 AM | #17 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
Yepp, another vote for the stock plate bolted to the frame rail. I am not a scale guy, i am a basher with an SCX10, but i did this just to get the servo lifted up and have the rear of the servo pointed up, so when i play in the water, it's much less likely to have issues with water getting to the elects in the servo... |
03-26-2013, 03:00 PM | #18 |
Im not using a 4 link on my honcho, i have the orginal with the upgraded strc y connect. Im building another scx10 hilux i have 4 linked though. I got the alum y cheap at my lhs as they were there for over a year so i bought them.
03-26-2013, 04:13 PM | #19 |
Pebble Pounder Join Date: May 2012 Location: Sherwood Park
Someone should make a kit that just adds a panhard setup for use with the stock plate. All you'd need is a filler plate, and an axle mount.
03-26-2013, 04:20 PM | #20 |
Double post. Delete this please
Chassis mounted steering question - Similar Threads | ||||
Chassis mounted steering for Wronchos and 1.9 Wraiths | BENDER | General Scale Talk | 11 | 07-17-2013 06:06 PM |
few problems with chassis mounted servo and steering | m1009cucv | Axial SCX-10 | 16 | 09-20-2012 06:38 AM |
Chassis mounted steering servo? | Duuuuuuuude | General Crawlers | 26 | 04-22-2009 01:08 AM |
Chassis mounted steering | elvis | Tamiya TLT Crawlers | 9 | 08-29-2005 04:56 PM |
Frame mounted steering question | outcastrc | General Crawlers | 17 | 03-19-2005 01:47 PM |
