03-24-2013, 06:51 AM | #1 |
Rock Crawler Join Date: Mar 2012 Location: UK, Hampshire
| Axial scx10 73 bronco
Hi guys, some of you might remember my comanche and jk, scx10 comanche -WIDENED CHASSIS- *UPDATE* * scx10 jeep jk * action pics * as you can see the chassis was widened by 2cm, this is a great modification to do but i just wanted to change up the layout of my truck, so instead of getting a new kit (which i don't really need) i decided to go back to the stock configuration. worked out really well. as you can see in the title it is going to be a 73 bronco, well i'm still waiting on the body to arrive as there is none in stock in the UK but it will resemble this truck : House's Bronco anyway here are some pictures of the 'new' chassis layout. battery plate bracket (cardboard) with battery plate mocked up on it here you can see that the electronics are all to the centre of the chassis and relatively low down for better weight distribution and COG. steering battery plate bracket drawn up on some 3mm scrap aluminium mandatory flex shot, i was not aiming for a lot of flex but there is a lot of flex for an almost stock configuration thats all for now, comments are much appreciated and i am happy to answer any questions. thanks for viewing. . Last edited by pobrockcrawler; 03-24-2013 at 12:17 PM. |
03-24-2013, 01:43 PM | #2 |
Pebble Pounder Join Date: Jan 2013 Location: Oklahoma City
| Re: Axial scx10 73 bronco
This thing looks mean! Is there a purpose for raising the steering links?
03-24-2013, 02:15 PM | #3 |
Rock Crawler Join Date: Nov 2010 Location: south prairie
I believe he did it clear rocks better. That's why I do mine that way. Links tend to get hung up on rocks and limit clearance.
03-24-2013, 02:20 PM | #4 |
| Re: Axial scx10 73 bronco What railripper said and basically to get a bit more steering angle as it clears the pumpkin you can get the same results from a bent steering link or high clearance knuckles, the one i done is the poor mans high steer clearance. haha
04-19-2013, 02:53 PM | #5 |
good news: got a call from my lhs and said my body shell has arrived, going to pick it up tomorrow and get it painted, can't wait to see what it looks like |
04-23-2013, 01:56 AM | #6 |
hi guys, got some pictures of my fresh body shell, turned out really well i think now for some outdoor pictures fixed the wheelbase so the wheels are now centered in the arches at articulation also my transmission had completely threaded to the point that the screws fell out while driving around, so i filled the holes with araldite and then i am going to drill the holes out and then thread them, hopefully this should work. with the holes filled in so my truck might not look like much at the moment, but i hope to cure this with some RC4wd 1.9 iroks and some custom bumpers and sliders. thanks for viewing, as usual, and if you have and questions i am more than happy to answer, comments are much appreciated . |
04-23-2013, 02:27 AM | #7 |
RCC Addict Join Date: Feb 2012 Location: UK
Looks great. I reckon some custom light buckets and some detailing on that rear Ford sign would be nice touches. |
04-23-2013, 01:20 PM | #8 |
| Re: Axial scx10 73 bronco |
04-23-2013, 01:24 PM | #9 |
Rock Stacker Join Date: Feb 2013 Location: lawerenceville
i like the look of the trucks stance i did raise my honcho up a bit to clear for a 2.2 tire so i did not have to cut the body but id agree on put some nice lights on the truck along with litt detail on the rear even a poss swing out spare tire rack would scale it even more but overall great looking truck
04-23-2013, 01:30 PM | #10 | |
| Re: Axial scx10 73 bronco Quote:
04-29-2013, 10:08 AM | #11 |
came up with a front bumper design, going to make it out of 5/6 mm brass tubing and then solder it together. first time making a bumper like that so i can't wait to see how it turns out. tell me what you think Last edited by pobrockcrawler; 06-23-2013 at 04:12 AM. |
04-29-2013, 10:23 AM | #12 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
Quick question...where the upper links attach to the axles, what type of mounting are you using? I have a pair of plates from STRC but I don't like the way they look.
04-29-2013, 10:26 AM | #13 |
04-29-2013, 10:29 AM | #14 |
Ok cool...thanks! Im sitting here with an AX10 drivetrain and wondering what to do with it. I like the bronco!
05-05-2013, 10:02 AM | #15 |
so my birthdays in a few few weeks and i thought i should get a little list ready for what i would like for my truck, just thought i would share it with you guys. 6 Lug Hitman 1.9 Scale 6 Bolt Beadlock Wheels Hex Mount Mount realistic Bolts | eBay King Off-Road Scale Piggyback adjustable alli Shocks Faux Reservoir 100mm Blue | eBay Interco IROK 1.9" Tyres (2) RC4WD with Foams Z-T0054 Wide footprint SOFT | eBay opinions welcome, thanks for looking. |
05-05-2013, 10:14 AM | #16 |
Quarry Creeper Join Date: Jul 2009 Location: Dublin,Ireland-Cluj,Romania
u can solve the transmision problem,by replacing with an alu one.and for my taste it will look better with 2.2 wheels.love the bronco body
05-05-2013, 10:25 AM | #17 | |
06-22-2013, 03:53 PM | #18 |
well it's been a while since my last update but my truck is now up and running, finally. I ended up replacing my transmission housing and the i realised i needed a new spur gear and then i had to get new body posts, so as soon as i thought i could drive my truck i couldn't, but anywho it is up and running now and i hope to take it out tomorrow. In the meantime here are some photos, oh yeah i added my roof rack. whats a thread without some articulation shots Thanks for viewing |
06-22-2013, 07:26 PM | #19 |
RCC Addict Join Date: Feb 2012 Location: Ca.
Love the early Bronco's. I've got one on my CR-01. When my Rubicon gets beat, it will get one too. Your Bronco looks great.
06-23-2013, 03:05 AM | #20 |
Axial scx10 73 bronco - Similar Threads | ||||
1.9 SCX10 Bronco | Colby | 1.9 Scale Rigs | 40 | 11-11-2011 02:48 AM |
