03-26-2013, 10:29 AM | #1 |
Quarry Creeper Join Date: Nov 2010 Location: Sarasota, Florida
| Gear Head four link question.
If I'm in the wrong section for this question, my apologies, not sure where to put this question. So I bought the Gear Head 4 link and now I'm having the problem of the servo plate not fitting, because the four link sits above the servo plate and not below it like the axial 4 link does, do I have to get a CMS kit to fix this or did I mount it wrong? |
03-26-2013, 11:51 AM | #2 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
| Re: Gear Head four link question.
if it's on your steering axle you may have to change to CMS or extend your servo mounts with spacers so the plate clears. usually people want a 3link/panhard setup up front and something like what you bought for the rear.
03-26-2013, 12:09 PM | #3 |
| Re: Gear Head four link question. I decided to try out a CMS, the level 3 RC one that's not the pan hard one was 12 bucks on sale so I bought it. You can have the servo sit below the frame or on/above the frame, two ways of mounting it.
03-26-2013, 12:22 PM | #4 |
Pebble Pounder Join Date: May 2012 Location: Sherwood Park
CMS doesn't work properly without a panhard or with a triangulated 4-link setup. You'll have bump steer, and the feedback will destroy servos.
03-26-2013, 12:58 PM | #5 |
Quarry Creeper Join Date: Sep 2010 Location: Gettysburg
The level level3 cms comes with a panhard bar. Make sure your use it cause if not youll get a ton of bump steer
03-26-2013, 01:07 PM | #6 |
Crap, I'm going to have to make a panhard.
03-26-2013, 03:05 PM | #7 |
With the axial 4-link setup, you need to remove an upper link (usually the left), for the suspension to work properly with the pan hard bar.
Gear Head four link question. - Similar Threads | ||||
Gear Head RC 4-Link Truss for Axial AX10 or SCX10 | Gear Head RC | Chassis and Suspension | 12 | 09-17-2013 03:40 PM |
NEW Gear Head RC 4-Link Truss for Axial AX-10 or SCX-10 (1) | RPP Hobby | RPP Hobby | 3 | 03-06-2012 03:37 PM |
Gear head 1.9 ute........... | OCMike | Tires and Wheels | 7 | 01-09-2012 12:50 PM |
Gear Head RC M3 Socket Head Screw Kit | Gear Head RC | Tools and supplies | 0 | 06-16-2009 07:29 PM |
Tamiya Gear Head Gear reduction ??? | TwistedXT | General Crawlers | 4 | 08-06-2007 12:33 AM |
