Thread: eric113's Portal axle JK
Old 03-28-2013, 09:32 PM   #1
Moderator Rule Breaker
eric113's Avatar
Default eric113's Portal axle JK
Current Setup
Front Axle
Locked RC F.I. locker
3racing portal
Traxxas stub shafts
Gunnar custom pins
Custom steering links
Axial Cvd's
STRC clockable C's
Axial stock gears
Rear Axle
Locked Up F.I. locker
Axial Stock gears
3racing lock out
3racing portal
Traxxas stub shafts
Gunnar custom pins
Axial 4 link mount
Axial stock inner shafts
Rolling Stock
Rc4wd Hummer wheels
Axial treps or custom 4.75" super swampers
Transmission
Axial steel ouputs
Axial stock motor plate
Gunnar pin for idler gear
10 tooth 32 pitch Robinson Racing pinion
60 tooth 32 pitch kimbrought Spur Gear
Driveshafts
Axial W8B driveshafts
Gunnar pins
Driveshaft mod
Suspension
4130 Chromoly lower links
4130 Chromoly upper links
Axial icon shocks
Chassis and Body
Axial Scx10 chassis
Hand Bro's Scx10 Cms kit
Rc bros servo clamps
Axial Jeep JK body
Axial stock JK front bumper
Axial stock JK rear bumper
Stock Axial hardware
Power and Control
Castle Mamba Max Pro waterproof ESC
Castle Creations BEC set @ 7v
Tekin roc 412 3100kv waterproof
Futaba S9157 steering servo
Racers edge servo horn
Futaba 4PK
Futaba R604FS RX
3racing winch
Heyok HV winch controller
QuickSand winch
1300mah 40c 4s sky lipos
eric113 is offline   Reply With Quote
Old 03-28-2013, 09:39 PM   #2
eric113's Avatar
Default Re: eric113's Portal axle JK
Inspiration came from google search and after seeing all the Axial Jeep JK pop up.
First I recycled the setup from my 2nd mog build and bought Axial jeep Jk body set,bumpers. When I bought the mog from Dezfan, I also bought his 3racing portals.
Following in Peli's steps... I started working with the rear axle tonight. Need to mark the holes, drill, tap them.
Old 04-27-2013, 06:45 PM   #3
eric113's Avatar
Waiting on some parts to get here for the wraith. I worked on the Jk.
I tired to bolt up the portals and failed I broke the tap off in the portal. The portal man himself Chino help me big time! He got the piece of tap out and the rear portals done for me.
I got the body rough cut. Did mock up with portals and tires I will be using for now.
Old 04-27-2013, 08:00 PM   #4
R2j
SORRCA Committee Member
R2j's Avatar
That looks mean Eric!
R2j is offline   Reply With Quote
Old 04-27-2013, 08:22 PM   #5
You shaving the ring gear and housing like your other portal rig?
TEDROCKZ is offline   Reply With Quote
Old 04-27-2013, 10:00 PM   #6
eric113's Avatar
Thanks Shon! The solders will look good on here. Maybe later on get some bumpers....
Sticking with non shaving. I got new housing's for the a other axles. Getting too custom.
Old 04-28-2013, 06:20 AM   #7
Great job As usual Eric.... The portals look right at home under that jk. Subed
Honchoforever1 is offline   Reply With Quote
Old 04-28-2013, 08:35 AM   #8
Looks good so far Eric! I like that winch on the front too!
SAL45 is offline   Reply With Quote
Old 04-28-2013, 11:41 AM   #9
eric113's Avatar
Thanks! It going to be slow but surely project.
Thanks! your JK is looking good too!.
This winch is hoss. I think, after talking to few people.. I'm going to get Tekin B1R esc for the winch controller.
Old 07-15-2013, 07:08 PM   #10
eric113's Avatar
I traded my first jk and started to miss it, made another trade.
Here go again and this one is to stay! It stock jk kit, brand new.
So far I added the portals and traxxas steel push rods for the rear upper links. Im not going super crazy with mods. Mostly stock with few upgrades.
Future plans:
Locked up lockers
R2j sliders
Corner guards
Old 07-15-2013, 07:44 PM   #11
I like this one better anyway looking good!
Old 07-15-2013, 07:49 PM   #12
eric113's Avatar
Thanks Honcho!
I still don't know what tires and wheel combo to go with...
Tires wise...super swampers in my earlier post or treps ?
Wheel wise.... TSS trail ready, axial wheels, rc4wd hummer wheels ?
Old 07-15-2013, 08:02 PM   #13
decisions decisions lol!
I think the hummer wheels would be cool with the portals. But that's a tough decision between the treps and swampers.
Old 07-16-2013, 03:17 PM   #14
~THE SCALE SHOP~
nice eric! not sure how i missed this!
love the gunmetal on the 2nd JK
STANG KILLA SS is offline   Reply With Quote
Old 07-19-2013, 11:11 AM   #15
eric113's Avatar
I got bunch small stuff done lastnight.
-Installed Gunnar pins in the WB8 driveshafts
-Mounted the quicksand winch with aluminum plate to sandwich
-Installed non slipper with Kimbrought 80t spur and RRP 18t pinion
-Regreased the trans with wheelworks Black & tacky
-Swapped out lower link rod ends to Traxxas rod ends and stainless steel set screws
Old 07-19-2013, 11:16 AM   #16
eric113's Avatar
It can be bad for your health to have too many decisions. But I think I'm going to with Hummers and swampers.
Thanks Cory! When I saw pics of the color, I loved it.
Since Handbros isn't making CMS kits anymore... I have one their servo mounts with mount cut off, I need to make a axle mount and block how to make it.
Old 07-19-2013, 01:22 PM   #17
Looks good Eric! I like the gunmetal color better!
Old 07-19-2013, 06:22 PM   #18
Tire&Foam Extraordinaire
Nova's Ark's Avatar
It's great to see you building Eric! Let me know when you're ready for some foams.
Nova's Ark is offline   Reply With Quote
Old 07-19-2013, 07:50 PM   #19
About flipping time you are getting this together looks great so far man. Portals look great also.
bagged86 is offline   Reply With Quote
Old 07-19-2013, 09:58 PM   #20
eric113's Avatar
One wheel and tire done. 3 more to go...:Shaking:
eric113's Portal axle JK - Similar Threads
Gmade portal axle Zrock General Crawlers 2 01-10-2016 09:01 AM
eric113's 2nd portal Mog eric113 Axial SCX-10 11 03-22-2013 10:00 PM
r1 portal axle bearings 530_crawler G-Made Crawlers 4 03-17-2013 01:10 AM
portal axle torque? Duxx G-Made Crawlers 2 06-08-2012 10:10 PM
