03-29-2013, 12:25 AM | #1 |
Rock Stacker Join Date: Oct 2012 Location: Dayton
| Whats the deal with mirroring the tranny?
What exactly does mirroring the transmission do? I know it eliminates the torque twist. But is it really needed? Im running a sidewinder sv3 / 4600kv motor in a scx10 dingo... Should I do said reversal? Does this save driveshafts? Does this affect crawling or trailing? Sent from my Samsung Galaxy S3- This thing has Tekin Hotwire |
03-29-2013, 06:50 AM | #2 |
Newbie Join Date: Oct 2011 Location: blairsville
| Re: Whats the deal with mirroring the tranny?
Mainly helps with torque twist...
03-29-2013, 09:32 AM | #3 |
Quarry Creeper Join Date: Feb 2013 Location: Coupeville, WA.
I recently did the tranny mirror and like he said above it helps with the torque twist. With that torque twist, your right front wheel will want to come up a lot under throttle. I do not want my front tires coming up any more than they have to especially when I am sitting on a 60 degree or better incline and trying to make forward progress. Plus it gives you the excellent opportunity to throw some water resistant marine grease in there to make it more water resistant. Oh and it definitely helps a lot, I have noticed a big improvement . . . well worth the 45minutes to do the job in my opinion.
03-29-2013, 10:37 AM | #4 |
Well thanks'! Im thinking im goig to do this mod.. Sent from my GT-P3113 using Tapatalk 2 |
03-29-2013, 12:14 PM | #5 |
Also helps to place the weight of the motor up front and at the passenger side, the weight bias up front is beneficial. An easy trick to know if you're doing it right.. on the motor plate, the word "axial" should be facing in towards the trans rather than out.
03-29-2013, 08:29 PM | #6 |
| Re: Whats the deal with mirroring the tranny? Good points here and remember also you are going to have to flip you tranny/motor plate around. This is what took me the longest and was the most difficult in my opinion. Almost classify it as a B word...i dont know about swearing on this forum... |
03-29-2013, 08:36 PM | #7 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
| Re: Whats the deal with mirroring the tranny? I don't understand what was so hard about this, I've done it several times and had no problems.
03-29-2013, 08:37 PM | #8 |
Rock Crawler Join Date: Jan 2012 Location: Champlin, MN
The flip vs mirrored confuses me. Could someone give me pictures of a before and after mirrored transmission? or even a after shot so I get an idea! |
03-29-2013, 09:25 PM | #9 | |
Sent from my Samsung Galaxy S3- This thing has Tekin Hotwire | |
03-29-2013, 09:33 PM | #10 |
| Re: Whats the deal with mirroring the tranny? |
03-29-2013, 09:43 PM | #11 |
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
Here ya go, photos! whats it mean to mirror the trans? |
03-29-2013, 10:01 PM | #12 | |
Sent from my GT-P3113 using Tapatalk 2 | |
03-30-2013, 10:37 PM | #13 |
| Re: Whats the deal with mirroring the tranny? The pain for me is taking out the transmission mount and flipping it 180. All the screws and then having to take it out from between the frame rails...hard might have been a strong word...annoying or PIA might be better terminology? Would be better just to do it from the start during a kit build.
03-30-2013, 10:52 PM | #14 | |
03-30-2013, 11:23 PM | #15 |
At least we only have to do it once . . .
Whats the deal with mirroring the tranny? - Similar Threads | ||||
Summit Mirror?? (Like Mirroring the axial tranny) | mtnhrdgr2 | Axial SCX-10 | 3 | 03-04-2011 03:24 PM |
Whats the deal? | jgammill | Losi Mini-Rock Crawler | 3 | 11-23-2009 08:50 PM |
mirroring an axial tranny | 92civic | Axial AX-10 Scorpion | 3 | 07-22-2009 12:21 PM |
Whats the deal???? | 66shift | Tamiya TLT Crawlers | 14 | 08-13-2007 03:30 PM |
Whats the deal with Sub C, AA | thistleb | Electronics | 4 | 08-03-2006 11:09 PM |
