03-30-2013, 08:21 PM | #1 |
RCC Addict Join Date: Aug 2007 Location: Burbank
| The docs jk custom
Here's the box, you know what it is, so I'm not going to bore you with all the pics of it I'm going to build it to be a wide frame like the 1.1. The stock kit frame is on the right, so its wide I'm using a Wraith crossmember and made the frame rails fit it. |
03-30-2013, 09:27 PM | #2 |
| Re: The docs jk custom
I got mine chassis table built and boy is it nice for doing frame or tube work. Set up to bend the Axial frame rail. Starting to set up the rear axle. Going to the out side like the real deal. |
03-31-2013, 08:22 AM | #3 |
Quarry Creeper Join Date: Jul 2011 Location: charlotte
cant wait to see how this turns out
03-31-2013, 09:10 AM | #4 |
Quarry Creeper Join Date: Aug 2009 Location: Snohomish, WA
Subscribed... Sent from my iPad using Tapatalk HD |
03-31-2013, 09:26 AM | #5 |
Rock Crawler Join Date: Dec 2007 Location: Maple Grove, MN
I'm gonna have to keep an eye on this one!
03-31-2013, 07:19 PM | #6 |
Well after almost all day I didn't like the way the suspension was working, so I went back to the lower links on the skid. With the lower links on the outside of the frame it had way to much rear steer. Plus I've been playing with shock positions on the rears, the frame still needs to be wider in the back to make the upper mounts work right, and I don't want to build a frame that is wider so they would work right. So I'm going to the out side on top. At this moment I'm going to keep the ICON shocks but may go to longer Kings, I'm not sure I like the upper mounts, just too close to the top of the frame. They should be taller. But it cycles great!! Here it is extended. Compressed mode. Made shock mounts and a doubler plate and brazed it to together for strenght. |
03-31-2013, 08:06 PM | #7 |
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
Those lower shock mounts are begging to get hung up on obstacles. I do like the custom fab work though. I was thinking of bending up a panhard mount using a similar method of attatchment.
03-31-2013, 09:07 PM | #8 | |
| Re: The docs jk custom Quote:
03-31-2013, 09:35 PM | #9 |
I could definately tell some R&D went into them and it looks like they may stay out of the way judging by those pictures, but it's hard to reproduce nature and the physics of a crawler in action in the laboratory though. I think rocks will surely find a way to grab onto those, though will probably be pretty uncommon. I'm imagining them bent back up the width of a rod end in order to mount a panhard bar. I love coming across threads that give inspiration. Speaking of G6 Yota and inspiration, I saw a build on a Toyota awhile ago when I was doing some searching which really hit the spot with me and that one in the background looks like it may be it. It came a fraction of an inch from pushing me to pick up some brazing supplies and starting my first real build. In the end I caved and just bought a JK body because as inspiring as it was, it crushed my dreams of being happy with whatever Frankenyota I'd end up with, lol. My favorite thing was the rear end tube work, how the 2 arcs crossed and wrapped around the spare tire. That rig as a whole just looks "right" if you know what I mean. |
03-31-2013, 09:58 PM | #10 | |
03-31-2013, 10:17 PM | #11 |
LOL, I'm pretty sure there is a positive correlation between weight and overall awesomeness. Mine only weighs 6lbs . So, you built that Yota, and now you are building this? Subscribed. |
04-03-2013, 12:54 AM | #12 |
Worked on a new shock mount design, not the final parts but just checking set up for now. New upper mounts too, built the 3 link and am working on getting the suspension articulation to work with out the shock spacers they want you to run. |
04-03-2013, 01:01 AM | #13 |
Cool fabbing. What CMS setup do you plan to run, will that be custom too? I'm really wanting to run CMS so I can mount my tie rod on top of the Axial high clearance knuckles, but I can't track down a Hand Bros kit and don't like the cheaper kits. I'll definitely be watching for ideas. |
04-03-2013, 01:15 AM | #14 | |
04-03-2013, 01:32 AM | #15 |
They are the high clearance AX10 knuckles which I think are similar height to the VP's. I wish I could just man up and make some bolt on brackets...That's the main thing hindering my move to CMS, the panhard mounts. I figure they need to be completely solid and I don't have the means to braze at the moment.
04-03-2013, 01:42 AM | #16 | |
04-09-2013, 09:56 PM | #17 |
Rock Crawler Join Date: Jul 2010 Location: youngstown , Hillbilly heaven
Looking good. Rear shock mounts look like the 1:1 for the most part. I like it. Spider9 would look sick under there. Lol. |
04-10-2013, 12:28 AM | #18 |
Steering servo is mounted, bracket for the battery tray and the body posts. Electronics box, and is going to be water proof. Installed the flairs and trimed the over lap off. Also raised the flairs a tad. Installed the vanquish knuckles. |
04-10-2013, 06:28 PM | #19 |
Why did you take the roll out of the front part of the chassis?
04-10-2013, 10:05 PM | #20 |
Newbie Join Date: Mar 2013 Location: Valencia
Is this the one you're building for your buddy you race short course trucks with? Lol
The docs jk custom - Similar Threads | ||||
The docs wraith | The Doc | Axial Wraith | 97 | 07-06-2013 02:59 AM |
docs test | rob_b | Testing 1 2 3 | 0 | 03-26-2011 11:25 PM |
