03-30-2013, 08:22 PM | #1 |
Pebble Pounder Join Date: Jan 2013 Location: Raleigh, NC
| What should I expect to break?
I'm running an SCX10 Honcho with the following: HiTec metal gear servo, aluminum servo horn, titanium steering links, Axial aluminum c-hubs and knuckles, beadlocked Irok 1.9's, allthread/tubed 4-link, Revo ends on all links, reinforced driveshafts. Electronics, axles, transmission are stock w/ NiMh battery, but currently running a 35T motor and 14T pinion. Going to test 45T and 13 & 14T pinions. Honcho is used primarily in rocks, and a little trail work. I'm primarily concerned about the front end and wonder what is most likely to break? I know from 1:1 that as you modify and add capability, steering tends to be the weak link. I think I'm ok there, but wonder what the next fuse will be? Axleshafts, r&p, ??? |
03-30-2013, 08:41 PM | #2 |
Sounds like a dam good rig.. Axial cvd's are a good bet for better steering an strength.. Been running mine for a year now on a 35t HH pro with a 15t pinion on 3s for scale courses an 4s for trail runs an g6..
03-30-2013, 08:59 PM | #3 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
| Re: What should I expect to break?
Sounds like your off to a good start with the mods, I would be looking at some steel gears/outdrives for your gearbox.
03-30-2013, 09:00 PM | #4 | |
| Re: What should I expect to break? Quote:
03-30-2013, 09:38 PM | #5 |
Quarry Creeper Join Date: Jul 2010 Location: Canada
Trans gears and outdrives probably the first thing to change
03-30-2013, 11:08 PM | #6 |
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
I wouldn't expect anything to break with your setup. This doesn't mean things won't wear out and fail over time. Run it and enjoy it until then.
03-31-2013, 02:34 AM | #7 |
Pebble Pounder Join Date: Mar 2013 Location: Honolulu
Agree with what others have said. I would not expect anything to break with what you're running. Even less likely if you go to a higher turn motor. You've already address the weakest areas. I'm not sure about the reinforced drive shafts though. Is that the stock shafts. I'd go MIP or Punishers. I also would change the trans gears to some Robinson's for piece of mind. These trucks are surprising strong. It took some getting use to going out with a RC and coming home with nothing broken!
03-31-2013, 04:15 AM | #8 |
Quarry Creeper Join Date: Sep 2005 Location: Geneva, FL
If you primary use is on the rocks even with a stockish set-up for electronics youll still want to replace the transmission gears with RRP or what AxialJeepster sells (if he can ever get them back in stock) because if you get into a bind and try to power out your tranny is the next weakest link.
03-31-2013, 06:25 AM | #9 |
Awesome, I really appreciate the feedback! Sounds like the transmission is the "fuse" now, so I'll address that next. I have been very impressed with this rig so far, the couple of issues I've had have been self-inflicted: thread locker is your friend. But otherwise it's been solid and very enjoyable. I threaded in bolts to the driveshafts to try and prevent twisting of the splined area. I think I'll hold off on upgrading them for the time being and do the transmission. Thanks again! |
What should I expect to break? - Similar Threads | ||||
what did he expect to see? | bigoggy | Chit Chat | 5 | 09-07-2011 07:14 PM |
is neutral break the same as drag break? | rod-211 | Newbie General | 3 | 02-25-2011 08:33 PM |
What should I expect? | Mighty1 | Axial AX-10 Scorpion | 4 | 11-22-2009 09:09 PM |
Does she expect us to believe this? | JasonInAugusta | Chit Chat | 15 | 05-15-2009 06:40 PM |
