04-01-2013, 10:23 AM | #1 |
Rock Stacker Join Date: Jan 2013 Location: Boise, ID
| Which Parts for Better Steering?
Hey, Guys. I am looking to upgrade the steering on my dingo. I have done a little research, but wanted ask to be sure. I am looking at doing the axial chubs and high steer knuckles. Is this all I will need? Will I have to have the cv's as well? Thanks!
04-01-2013, 10:33 AM | #2 |
| Re: Which Parts for Better Steering?
The dog bones may start to bind if you steer to far. The universals are a good upgrade. Also, over drive and under drive gears really help turning radius. |
04-01-2013, 10:54 AM | #3 |
Thanks for the good info. The universals aren't cheap - wanted to be sure that they would be worth it. So it looks like I will need: chubs knuckles universals diff gears |
04-01-2013, 11:35 AM | #4 | |
| Re: Which Parts for Better Steering? Quote:
To get the additional range you will need to have the universals. I had some breakage issues with the Axial universal joints. I was breaking pins so I replaced them with gunner pins. Solved the broken pin problem but I broke the axle stub where the pin goes thru. I am in the process of doing a new build using the Vanquish VVD's. They seem to be built stronger than the Axial parts but cost a lot more. There seems to be a mixed opinion on them in the Vanquish area here on RCC. | |
04-01-2013, 11:47 AM | #5 | |
04-01-2013, 12:41 PM | #6 |
Rock Stacker Join Date: Oct 2008 Location: In the Middle of a Corn Field
Not to High Jack a topic, But what do you mean by over drive/ under drive?
04-01-2013, 12:42 PM | #7 | |
04-01-2013, 12:43 PM | #8 |
| Re: Which Parts for Better Steering? |
04-01-2013, 12:57 PM | #9 |
I guess I'll have to just get the front end parts and measure how long of a tie rod I will need? Where do you get the tubing?
04-01-2013, 12:57 PM | #10 | |
You can have R2J make you a custom tie rod out of stainless if you need more strength or bling factor. | |
04-01-2013, 01:00 PM | #11 |
Thanks. It's surprising that axial doesn't make a tie rod to fit their upgrade parts...
04-01-2013, 01:03 PM | #12 |
04-01-2013, 01:08 PM | #13 |
That should be easy enough.
04-01-2013, 01:13 PM | #14 | |
I have them on my Honcho and they helped. Using universals buys you more than the high clearance knuckles. On my JKU build I decide to use STRC CHUBS / Knuckles to help bring the budget back in line after buying VP lockers and VVDs. | |
04-01-2013, 01:41 PM | #15 |
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
You can bend and lengthen the stock aluminum tie rod, if that's what you have right now, to work with Axial high clearance knuckles. If you have something to use for spacers is definitely the frugal way to attack the tie rod issue with high clearance knuckles. You can see here the spacers I've added to each end. I used what were shock spacers for my Losi which are the perfect diameter. I had a bunch of different thicknesses so I was able to fine tune the toe. Note that unlike stock, where both links attatch to the top of the knuckle, the tie rod is now on bottom, and drag link is on top. The bend is so the link clears the axle during full lock with the sharper steering angle. Last edited by 05Fronty4x; 04-01-2013 at 01:55 PM. |
04-01-2013, 02:55 PM | #16 |
The pics help. Thanks.
04-01-2013, 09:19 PM | #17 | |
04-01-2013, 09:42 PM | #18 |
The parts to make the tie rod and drag link are: ax30516 6x 106mm x1 Tie Rod ax30517 6 x 33mm x1 drag link ax80005-2 rod ends x2 ax80005-1 rod ends x2 ax80018 Ball ends x4 axa186 M3 x 16mm set screw axa1413 1x6 mm spacer -- Used to add length axa1414 2x6 mm spacer -- Used to add length |
04-02-2013, 12:23 PM | #19 |
Thank you very much!
04-11-2013, 08:22 PM | #20 |
Got the high steer knuckles installed and the steering horn looks too long. It looks like the horn is going to hit the tie rod. I haven't redone the tie rod yet, so I cannot fully cycle the steering. I have a pic, but cant figure out how to post it.
Which Parts for Better Steering? - Similar Threads | ||||
Steering parts? | Erock | General Scale Talk | 9 | 05-03-2010 01:16 PM |
the new axial steering parts............... | bob1961 | Axial AX-10 Scorpion | 7 | 10-29-2008 05:27 PM |
steering parts for nylints | muddyblzr | General Crawlers | 1 | 09-01-2007 03:44 PM |
Steering Parts | lesannatrevor | HPI Wheely King | 6 | 07-21-2007 04:54 PM |
