04-01-2013, 11:28 AM | #21 | |
Rock Crawler Join Date: Jan 2012 Location: Mcallen, Tx
| Re: Overdriving the Front Axle? Quote:
while the might be true, ive actually tried both, OD only and UD only, and with the UD only i felt less torque and i kinda wanted to change my gearing, but for the best outcome and performance, IMO either run both or OD only | |
04-01-2013, 11:32 AM | #22 | |
whatever you do dont listen to anyone on wheel weights, yess 2oz-4oz in the fronts with work, some are hardcore and run 4oz in all 4 some run 4oz in the front (just a hypothetical weight example) and some will run none, just try it out. like i said earlier get out there and try it out! some rigs are rear heavy and need front weights some rigs are front heavy and dont need weights if at all. its all up to you and your rigs behavior. | |
04-01-2013, 11:41 AM | #23 | |
RCC Addict Join Date: Mar 2009 Location: Chilton
04-01-2013, 11:48 AM | #24 | |
04-01-2013, 12:24 PM | #25 |
Rock Crawler Join Date: Jan 2006 Location: Bellaire, MI
Good info, I think I am going to try the ud/od in my Wraith since I do a lot of hill climbing.
04-01-2013, 12:40 PM | #26 |
Rock Crawler Join Date: Sep 2012 Location: Roxborough, CO
This was great information for me - just ordered front and rear od/ud hd gearsets for my JK build! Thanks! |
04-01-2013, 12:45 PM | #27 |
One question now that I am thinking more about it - how does this affect tire life with softer compound tires? Is it a noticeable difference? Thanks! |
04-01-2013, 12:49 PM | #28 |
| Re: Overdriving the Front Axle? I havn't been able to tell a difference in wear. I run pitbulls on that truggy and have been running trails and rock with it. I am sure if you run alot of concrete it will make a bit of a difference but mine hasn't even sat on concrete so I couldn't say for sure.
04-01-2013, 12:58 PM | #29 |
Great - thanks again! |
04-01-2013, 01:02 PM | #30 | |
and i currently run OD and UD in my jk with treps @ 7lbs 4oz and theres no difference in wear, unless your a brushless guy and have a heavy foot running on bare rocks then yessir, they do disappear fairly quick regardless of OD or UD | |
04-01-2013, 01:02 PM | #31 | |
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
While having the stock ratio in one axle, the difference between the other 2 (UD/OD) ratios compared to the stock ratio is so small you wouldn't ever know the difference, and if you did notice the difference (as you state you have) you should have actually noticed the opposite effect since 43:13 is a lower ratio. And even more contradicting is that it sounds like you favor a high offset by recommending both, yet you choose to put 36/14 in the front if you were to only do one. This is totally bass ackwards since that offers the least amount of offset possible. Just overdriving the front is closer to stock than just underdriving the rear. It kind of sounds like you are stuck on the terms and not really breaking through to the concept. What if our rigs came with 43/13...your arguement is that it's better to overdrive the front. Well, that puts you at 38/13 in front, and 43/13 in rear and that is exactly what "underdriving" is for us since they come with 38/13. If the offset from stock wasn't so close to identical between our OD/UD options then there would be more room to favor one or the other. | |
04-01-2013, 01:03 PM | #32 |
| Re: Overdriving the Front Axle? Your front tires will wear out faster no matter which option you go with since they will be turning faster than the rear. Assuming equal traction with all 4 tires of course.
04-01-2013, 01:07 PM | #33 |
| Re: Overdriving the Front Axle? |
04-01-2013, 01:10 PM | #34 | |
they might just be "terms" and "concept" to you and here we go again YOUR opinion, but whats sounds good and makes sense on paper doesnt tranfer perfectly over to the trail since we are almost literally on 2 different corners of the country, now IMO yes front OD only or BOTH works best, remember IMO and geez dont scare the guy, the front DO NOT drastically wear differently, and as before mentioned unless your a throttle guy, you'll be fine as far as wear, and just follow the rule of thumb of tire rotation front to rear and vise versa, i usually rotate mine every other trail ride maybe 2-4 trails and ive never noticed a difference in wear and ive always run OD and UD in my axles. Last edited by Big Tex; 04-01-2013 at 01:15 PM. | |
04-01-2013, 01:25 PM | #35 |
| Re: Overdriving the Front Axle? Again... Stock (38/13) = 2.92:1 Over (36/14) = 2.57:1 or a .35 offset Under (43/13) = 3.31:1 or a .39 offset ... or do both for a .74 offset What you are saying is that an offset somewhere between .35-.74 works best... guess what? .39 (UD rear) falls into that category. Yes, opinion this, opinion that...I'm leaving my opinion out on the matter by indroducing factual information. Your opinion is based on your "feel" that day, for all that matters it could have been the position of the moon, or what you ate for breakfast. Suggesting to put 36/14 in the front, or do both, but not just the rear doesn't make a bit of sense since doing just the rear falls right in between the two. I'm not doing it for you, or because I think you need it. I'm doing it for those who want a little more substance than what pure opinion offers when they take the time to research. Last edited by 05Fronty4x; 04-01-2013 at 01:30 PM. |
04-01-2013, 02:53 PM | #36 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
| Re: Overdriving the Front Axle? Thanks for the input all. I am confident I made the right choice now. |
04-01-2013, 03:45 PM | #37 |
Quarry Creeper Join Date: Sep 2010 Location: Gettysburg
Anyone have a link to the parts need to overdrive the front axle? Thanks
04-01-2013, 03:53 PM | #38 |
The ax 30395 gear set is the heavy duty stock replacement set, also by the picture in the link its straight cut gear and pinion. The ax30402 gear set is the heavy duty underdrive gear set, also its bevel cut. The ax30401 gear set is the heavy duty overdrive gear set and is also bevel cut. That is a start for axials I find almost all manuals on google in pdf by searching the model name then manual & pdf. Most manuals cover upgrade and optional parts (including part #'s) |
04-01-2013, 04:03 PM | #39 |
04-01-2013, 04:23 PM | #40 | |
YES they make sense, YES the rear makes more sense FACTUALLY, but here we go again, IMO i rather have my front end spinning faster and my rear spinning at factory speed, than my rear spinning slower and my front at factory speed, if you wanna get factual, this ENTIRE argument is over .04 of a ratio, literally the most indestinct difference in wheel speed ever, all i stated was my opinion because thats all anyone asked for, and thats all that gets posted is opinions, cool, thats all anyone has to offer someone with a simple question, no one wants to get scientific about this hobby, especially over .04 of a difference in a gear ratio, now please, i get it that this is your factual opinion, awesome bud, really, now let my opinion stand for what it is, just my opinion, and btw yes the moon and the stars were in perfect alignment and i had my wheaties | |
Overdriving the Front Axle? - Similar Threads | ||||
Narrowing front Wraith Axle for front of scx10 | rusty577 | Axial SCX-10 | 12 | 02-02-2013 10:30 PM |
Overdriving the front | new2it | EnRoute Berg | 7 | 01-20-2012 03:46 PM |
LNC front axle teardown/axle shaft removal guide? | LowLock | Team Losi Comp Crawler | 1 | 05-22-2011 09:31 PM |
front steering linkage behind front axle kit? | slip408 | Axial AX-10 Scorpion | 8 | 09-14-2008 01:16 AM |
