04-02-2013, 12:14 PM | #1 |
Pebble Pounder Join Date: Mar 2013 Location: london
| scx 10 knuckle problems
Hi I have the scx10 honcho with vanquish aluminum knuckles anyway the two screws were the knuckles screw on keep coming loose and actually fall out after about 30 min of run time what is a good way to keep tjem in but not where you cant get thwm out if u needed to
04-02-2013, 12:16 PM | #2 |
Rock Crawler Join Date: Jul 2012 Location: Grand rapids
| Re: scx 10 knuckle problems
Use some blue lock tight not to much though, and let sit over night should be good to go, that's what I did on my wraith and Scx
04-02-2013, 12:44 PM | #3 |
Quarry Creeper Join Date: Nov 2008 Location: NorCal
The very best fix for this issue is a bit costly and time consuming, but IMO well worth the effort... install a set of Beef Tubes in the front axle! Once the tubes are installed you would use fine-thread machine screws (instead of course thread self tapping screws) that would screw into the threads of the tubes which will provide a good strong anchor point to attach your C-hubs to ... don't forget the blue thread locking compound ETA: Whoop's! After re-reading your post, I see you are referring to the steering knuckle screws... blue thread lock should still be the fix. Last edited by BodiBuilt; 04-02-2013 at 12:47 PM. |
04-02-2013, 01:00 PM | #4 | |
Rock Crawler Join Date: Jan 2012 Location: Mcallen, Tx
| Re: scx 10 knuckle problems Quote:
So remove it all, get some diff lube on a q-tip, lube up the knuckles eyelets where the bushing goes liberally. Re-insert it, and use loctite on the hardware, keep your allen wrench in the screw head, and cycle your steering full left and full right a couple times to work in the grease on the plastic bushing. Then let sit over night and your golden! i do this on all my joints, keep em wet and well lubed (in a good way) | |
04-02-2013, 01:19 PM | #5 |
Rock Crawler Join Date: Feb 2010 Location: in a Fishbowl watching time go by
In the above post he mentioned plastic bushings......If your bushings are plastic get new metal ones..they are called flange pipe on Rpp . my two cents..
04-02-2013, 01:23 PM | #6 |
Would red loc tite work
04-02-2013, 01:33 PM | #7 |
Beef tubes do work great on the front end , don't use red lock tight unless you plan on never taking the front apart at some point for repairs
04-02-2013, 02:23 PM | #8 |
Well im in a perdicament so I had to use the red loc tite. Im kinda in a comp with some friends and were in the kiddle of nowhere staying all week crawling and camping and we have a friendly wager between us a kinda comp between friends lol and it wou ld be cheaper to loctite these and I could buy a new pair if I ever needed to later on. Since im winning and hopefully stay winning ill have a little extra cash I can get more parts
04-02-2013, 02:28 PM | #9 | |
thats always the best way to go, take their money and show em your shiny new parts! | |
04-02-2013, 02:44 PM | #10 |
haha right I hope to god I keep up the pace im in bc these guys have more experience than I do but with this forum and my constant practicing im getting better by the day I do have a question I know its supposed to dry in 20 min and then cure for 24 hours would It hurt if I took it out before the 24 hours is up
04-02-2013, 02:52 PM | #11 | |
ive put loctite on screws in trail repairs, used my rig for a couple hours and upon getting back home the screws were barely starting to back out, maybe 2-3 turns at the most, maybe not even that. and other instances ive put loctite on, waited 48-hrs (fri-sat) and then took my rig out for a g6 style sunday comp and had em back out the first hour so it all depends on how heavy your foot is, lol. but you should be good after 20min if not, keep an allen wrench in your jean pocket, ive done it, and trust me stopping to tighten it 2-1/2 turns every 30min wont hurt | |
04-02-2013, 03:39 PM | #12 |
sounds good im fixing to run her again well see how it goes this time lol
scx 10 knuckle problems - Similar Threads | ||||
Scx-10 problems | CelicaJosh | Newbie General | 5 | 02-14-2013 11:07 PM |
scx 10 steering knuckle & 2.2 tires? | Barndog Racing | Newbie General | 9 | 12-31-2012 09:56 AM |
problems on a scx 10 with gmade axles | Reaper.aa | Axial SCX-10 | 2 | 07-06-2012 12:27 PM |
SCX 10 Receiver and Servo Problems | jray | Newbie General | 7 | 09-05-2011 11:05 AM |
