04-04-2013, 03:58 PM | #1 |
Newbie Join Date: Mar 2013 Location: on the rocks
| Shock setup idea
i currently run stock scx10 shocks with a level 3 rc lift kit. I was thinking about flipping the left over so it is a "droop" and running RC4WD 110mm shocks. Would this work and would this be a good idea?
04-04-2013, 04:00 PM | #2 |
| Re: Shock setup idea
That makes no sense whatsoever. What's your reasoning?
04-04-2013, 04:03 PM | #3 |
i want a little more travel from my shocks...
04-04-2013, 04:08 PM | #4 |
Rock Crawler Join Date: Jan 2012 Location: Champlin, MN
so we're clear you want to have longer shocks but mount them higher up instead of downwards which would completely negate the benefit of longer shocks would it not? |
04-04-2013, 04:12 PM | #5 |
i wouldnt put them all we way up, i would put it on the firsy hole in the middle after its flipped
04-04-2013, 04:13 PM | #6 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
what you want is basically what a "droop bracket" does. should work but you might not be able to take advantage of all the up-travel depending on whatever other mods you have. intashu - yes and no to your question. mounting longer shocks higher up will keep the same ride height but will benefit from more travel. |
04-04-2013, 04:15 PM | #7 |
Yes, thanks Perkolator
Shock setup idea - Similar Threads | ||||
My first mod idea..shock limiter | foodstick | Losi Mini-Rock Crawler | 6 | 11-02-2009 04:31 PM |
Shock question.. idea... info... | Double J | General Crawlers | 5 | 02-25-2006 09:06 AM |
Shock idea | Bill8Bud | General Crawlers | 2 | 10-24-2005 03:51 PM |
