04-07-2013, 02:19 AM | #1 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| Got a question for you about a Scx10
can I make my short wheelbase SCX10 into a long wheelbase by changing the lower links, that are 6x91mm front and rear, to 6x98mm front and rear 6x106mm lower links, but how do you figure the length of the upper links,my truck has the hard pan kit,the rear is four link, cause I looked,online the frame rails, are the same, so is skid plate, so the inch difference in wheelbases must be in the different length lower links, so does the upper link length change, cause I want to make mine a long wheelbase. so any info would be great
04-07-2013, 03:15 AM | #2 |
Quarry Creeper Join Date: Feb 2013 Location: Coupeville, WA.
| Re: Got a question for you about a Scx10
yes you would need to lengthen your uppers also otherwise it would rotate (clock) your axle forward and give you a bad driveline angle. A lot of people (including me) run the same length links upper and lower in the rear to clock your axle up. This gives you a better driveline angle. I do not recall the exact length you need, but it is in the forums here. search how to make your own links and it will be in there somewhere.
04-07-2013, 07:09 AM | #3 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
98 front and 106 rear will give you the honcho/ jk wheel base of 12.3 upper and lower i have to to run a little spacer in my front uppers to clock my axle other wise my drive shaft binds hope this helps
04-07-2013, 08:54 AM | #4 | |
| Re: Got a question for you about a Scx10 Quote:
http://docs.axialracing.com/instruct...cx10-links.pdf http://docs.axialracing.com/instruct...cx10-links.pdf Last edited by k7zpj; 04-07-2013 at 09:08 AM. | |
04-07-2013, 09:06 AM | #5 |
Pebble Pounder Join Date: Mar 2013 Location: london
Yup these guys in the above post seemed to have handled it for u and gave u good info.
04-07-2013, 09:58 AM | #6 |
thank you guys very much
Got a question for you about a Scx10 - Similar Threads | ||||
new scx10 question | DyrtyByrd | Axial SCX-10 | 7 | 07-15-2010 02:10 AM |
scx10 question | civichbboy | Newbie General | 2 | 12-16-2009 02:29 PM |
scx10 question | rckid14 | Axial SCX-10 | 3 | 08-26-2009 01:57 PM |
SCX10 question | 53HRA | General Crawlers | 7 | 08-05-2009 04:45 AM |
Got my SCX10 have question? | 4xfloored | Axial SCX-10 | 15 | 02-03-2009 01:27 AM |
