04-08-2013, 10:29 PM | #1 |
Rock Stacker Join Date: Oct 2008 Location: In the Middle of a Corn Field
| Dingo Rear Axle issues
Hi, I am working on a dingo kit... I tried to run it for the first time and I have issues with the rear end.. When I give it throttle, the rear end starts to chatter/jerk/wobble.. Its hard to explain, So I took off the rear drive shaft to insure that it wasnt something to do with the transmission and ran it fine.. I take off the front drive shaft and run it and it does it... So I took off the tires on the rear and ran it... It was fine... I have no idea what it is, I tore it apart and didnt see anything wrong. Any ideas? I did notice that the plastic shells are a little warped.. not sure if that is what is causing this? |
04-08-2013, 10:33 PM | #2 |
Quarry Creeper Join Date: Mar 2009 Location: Grande Prairie, AB, Canada
Pics would help Sent from my GT-I9100 using Tapatalk 2 |
04-08-2013, 10:41 PM | #3 |
| Re: Dingo Rear Axle issues
I can get a video but it will take awhile for it to upload...
04-08-2013, 10:50 PM | #4 |
Quarry Creeper Join Date: Mar 2013 Location: Plymouth
What speed/throttle position is the chattering/wobbling happening at? Is the rear driveshaft splined correctly? Cuz if it is not, that will cause vibration issues. How bad is the wobbling and chattering? The "shells" axle housing will have a bend to them. It happens. Do you feel any grinding or tightness in the ring and pinion when rotating them by hand? Does it still do it if you give it throttle when the wheels and tires are removed?
04-08-2013, 10:56 PM | #5 | |
| Re: Dingo Rear Axle issues Quote:
Axial Dingo Rear end issues - YouTube | |
04-09-2013, 01:31 AM | #6 |
Newbie Join Date: Feb 2013 Location: San Jose
Try checking the length of the upper rear links. I had a similar issue where under load the driveshaft would bind a bit. Check the angle of the pinion and make sure it's not pointing downward or close to 90*. If you are looking at the rear end from either side, driver or passenger, look at the angle of the rear output shaft where the driveshaft connects to the rear end. It should point a little upward. If its pointing down, try lengthening the upper link ball ends to bring the angle up a bit. Hope that helps! Just noticed your video. Not sure if my comment will matter but it's worth a look. Can you post a photo of the driveshaft angle in the rear? Last edited by wakeside; 04-09-2013 at 01:35 AM. Reason: Added info |
04-09-2013, 05:51 AM | #7 |
Rock Crawler Join Date: May 2012 Location: Columbus
I just had this problem and never found out why axial just had me send it in and they sent 2x 2s lipos and a RTR honcho I clocked the axles lined up notches on the drive-shafts Last edited by Ohioskills; 04-09-2013 at 06:00 AM. |
04-09-2013, 09:11 AM | #8 |
Quarry Creeper Join Date: Apr 2012 Location: San Jose, CA
I was running a 55T motor and my Dingo ran smooth. I just swapped in a 27T Axial and it started behaving exactly like yours. I need to lengthen my upper links to improve the driveshaft/pinion angle like Wakeside suggested and see if it improves.
04-09-2013, 11:00 AM | #9 |
It is running the stock upper links.. What would be the best option to add length to them?
04-09-2013, 11:33 AM | #10 |
IIRC, the stock uppers are plastic right? The only real option there is to either make them or buy the link upgrade. Did you check the angle of the pinion to see if its pointing towards the ground or not? If Debonair had a similar issue after changing the motor, Im not certain its a link length issue. Have you also tried to email axial support? I've heard mixed results from their customer support but I've also heard of some stories where they simply replaced the whole setup for some customers. |
04-09-2013, 12:36 PM | #11 |
The 27T moves my Dingo way faster then the 55T (obviously) so the issue was probably there the whole time, I was just too slow to know. I have custom uppers so I am going to lengthen them and see if it helps. After that maybe I go to Axial. Between this and the smoked ESC i think my Dingo hates me. |
04-09-2013, 12:37 PM | #12 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
as long as you've installed the correct links for the kit, in the correct places - there shouldn't be any driveshaft issues. in your video, you have 2 different tires going on the rig - is it happening with both sets when bolted down? where are your axle housings warped at? lastly, approximately how much runtime total has this rig seen?
04-09-2013, 12:55 PM | #13 |
I figured it out... It was the pinon pointing at the ground. What i did was add washers to the end of the stock link and that forced it up and now it is working perfectly fine..
04-09-2013, 08:38 PM | #14 |
That's great news man! I'm glad you got it sorted out. Like perk said, you shouldn't have had the issue to begin with but you never know. Maybe you have a part in the wrong place? Either way, good news. @debonair, when you get setup, let me know so we can crawl penitencia sometime or pm me when you are good to go. |
04-09-2013, 11:37 PM | #15 | |
For sure. | |
Dingo Rear Axle issues - Similar Threads | ||||
Rear differential issues? | Kanine38 | Axial AX-10 Scorpion | 18 | 05-18-2010 05:48 PM |
issues with rear axle build | slegh | Tamiya TLT Crawlers | 6 | 06-02-2008 08:57 AM |
