04-11-2013, 09:14 PM | #1 |
Rock Crawler Join Date: May 2012 Location: Columbus
| MIP shaft problem
after searching about them i picked some up but this is what I ran into running 20 pinion and 89 spur and they do hit??? |
04-11-2013, 09:22 PM | #2 |
RCC Addict Join Date: Aug 2007 Location: Burbank
| Re: MIP shaft problem
You can get a longer out drive from MIP and it will put the shaft out farther. MIP11117 |
04-11-2013, 09:28 PM | #3 |
| Re: MIP shaft problem |
04-11-2013, 09:40 PM | #4 |
| Re: MIP shaft problem Sorry, I didn't see the hole pic, the screw was off my screen and I just saw it. The longer out drive will help with the teeth hitting if they are and I see you sanded the backing plate, thats what I also do...... Just get a shorter set screw and it will clear.
04-12-2013, 05:17 AM | #5 |
the set screw isn't in all the way but good eyes and answer man
04-12-2013, 08:21 AM | #6 |
sorry 2x post but also what do i use for a set screw i just used thread locker and tighten it down pretty good
04-12-2013, 08:47 AM | #7 |
Rock Crawler Join Date: Sep 2011 Location: Sandusky, Ohio
04-12-2013, 08:55 AM | #8 |
well thanks bud
MIP shaft problem - Similar Threads | ||||
MIP shaft problem | TLWP | Axial SCX-10 | 8 | 01-03-2011 08:17 PM |
