04-13-2013, 06:11 AM | #1 |
Pebble Pounder Join Date: Mar 2011 Location: coastal georgia
| SCX10 frame rail dimensions
Any of you all have, or can point me to, dimensioned drawings of the frame rails? I searched and found the basic width, thickness and length of the C channel. |
04-13-2013, 07:49 AM | #2 |
Quarry Creeper Join Date: Jan 2012 Location: Mooresville, NC
I traced a frame rail set years ago. I took all the length measurements / height measurements. Its a crude drawing but has worked like a charm for me. You'll have to wait till Monday cause Its at work but I can post up the pic then. Sent from the end of my fingertips |
04-13-2013, 08:21 AM | #3 |
| Re: SCX10 frame rail dimensions |
04-13-2013, 10:46 AM | #4 |
04-14-2013, 10:50 AM | #5 |
The one from 3D warehouse shows a slight offset in plan view. Is that correct, or is the rail flat? Another question- Is there some advantage to it being C channel? Or can it be a solid bar of say aluminum? |
04-14-2013, 11:48 AM | #6 |
I have made them out of solid bar, square stock (then cut in half) and flat aluminum. As long as you have cross bar support, you should be fine. Sent from the end of my fingertips |
04-14-2013, 02:16 PM | #7 |
Solid is way easier to fab for me. I can have it water jetted or milled. I cut some 1/2" square tube in half length wise to mess around with. I can make the C channel match the Axial shape if necessary, but are you guys fabbing this part as a straight rail? |
SCX10 frame rail dimensions - Similar Threads | ||||
Frame rail measurement. | offroad1911 | Axial SCX-10 | 3 | 02-01-2012 08:02 PM |
Frame rail length | Crawlerguy851 | Newbie General | 1 | 04-04-2006 07:39 PM |
bruiser frame rail dimensions | XCUTIONER | Tamiya TLT Crawlers | 2 | 07-22-2005 06:06 PM |
